-   -   First Engine Drop (http://forums.pelicanparts.com/porsche-911-technical-forum/1083579-first-engine-drop.html)
Funracer 03-13-2021 01:22 PM
“I believe the TT on the left side chain cover and 15 degree switch on the right are the same threads.”
After looking at it again today it appears they are not the same thread.
Funracer 03-13-2021 02:11 PM
Found two sources that agree the thermo time switch threads are M14x1.5.
Google is wonderful.
Funracer 03-20-2021 03:45 PM
Is this a leaking rocker shaft seal? It’s on the exhaust side at the front of the motor.
Notice the intake side is dark but not wet.
http://forums.pelicanparts.com/uploa...1616280165.jpg
Or is that large plug leaking?
gomezoneill 03-20-2021 04:04 PM
Originally Posted by Funracer (Post 11203345)
Not planning on that until it gets to 250,000 miles. Or I find something that makes me do it, whichever comes first.
That engine needs a overhaul no getting around it. Do what you have to do.
Funracer 03-20-2021 04:22 PM
Only 107,000 miles. Should last a lot longer. Does leaky = overhaul?
kgieg 03-21-2021 10:34 AM
I would think it is the freeze plug there. These engines are hard to keep from leaking. Have you ever read the engine sealant thread? It is years long and when I read it before rebuilding my 2.7 I still had questions on proper sealants for different areas of the engine. This was a few years ago, runs great still leaks some places, but it's also a mag case 2.7. You might have better luck with a 3.0.
gomezoneill 03-21-2021 11:30 AM
Buy these !
https://www.pelicanparts.com/catalog/accessories/101-projects-books.htm
Funracer 03-21-2021 08:08 PM
Originally Posted by gomezoneill (Post 11267939)
Got them! Thanks
Funracer 04-05-2021 10:27 AM
This reseal project began because I was unhappy with the amount of oil on my garage floor. My oil return tubes were in backwards (as pointed out by several sharpies earlier) so that was an obvious source and easy fix.
But a lot of oil was coming from up high on the number 6 cylinder corner. First thought is the oil cooler, but when I pulled it apart there was no evidence of a leak. But plenty of oil was between the cooler and the forward side of the motor:
http://forums.pelicanparts.com/uploa...1617642869.jpg
It looked like oil was escaping from the number 6 exhaust rocker shaft. This led me to order RSR seals. Today I put them on the 4-5-6 exhaust and intake rocker shafts. I took out 5 bone dry rocker shaft bolts but cylinder 6 exhaust bolt was soaking wet. Hard to take a good pic but you can see the shiny one on the left.
http://forums.pelicanparts.com/uploa...1617643130.jpg
Hopefully these seals will take care of that leak.
Funracer 04-08-2021 08:32 PM
Been putting this day off but finally got it done. Cleaned out the engine bay with Dawn and brake cleaner, then stripped out the AC lines and charcoal canister lines.
After cleaning, replaced all the engine compartment perimeter seals and the sound barrier. White paint stained with oil and grease is tough to get spotless. To be perfect it needs new paint but thats not happening. Given the state it was in I am really happy how it turned out.
http://forums.pelicanparts.com/uploa...1617938822.jpg
Quasimoto 04-09-2021 03:04 AM
That looks pretty good! I think I would lose my mind with a white engine bay, lol
911 Rod 04-09-2021 06:23 AM
"charcoal canister lines"
Are they not for the evaporator system for the fuel tank?
Funracer 04-09-2021 07:19 AM
Yes I believe so. I thought it was common to remove it. I pulled the line off at the rear tunnel connection. From there to the fuel tank is still in place.
Showdown 04-09-2021 07:28 AM
I was under the impression that the charcoal canister and lines were necessary to keep your garage from smelling like fuels and more importantly your wife happy...?
Funracer 04-09-2021 08:11 AM
Just did a search and read up on it. May to have to put it back in. Easy enough since I still have all the pieces. Thanks for the catch!
Funracer 04-23-2021 12:28 PM
Coming along!
http://forums.pelicanparts.com/uploa...1619205910.jpg
No show car for sure but much improved so far.
Got to get a new coil bracket!
Funracer 06-22-2021 08:16 PM
http://forums.pelicanparts.com/uploa...1624417827.jpg
http://forums.pelicanparts.com/uploa...1624417960.jpg
These stainless heater valves, new hardware and hose are a nice upgrade. Really cleans up that area.
Mike Andrew 06-23-2021 06:10 AM
Did you break/replace any of the studs holding the heat valves? Installation looks very good with the new hardware.
I have a set of rebuilt flappers waiting to go in when it's clutch time. Worried about breaking the old and rusty studs, even if soaked with PB or similar.Looks like a tough area to do any welding.
Funracer 06-23-2021 04:25 PM
No broken studs thankfully. The old ones came off pretty easily.
Quasimoto 09-08-2021 02:19 AM
Update?
