-   -   First Engine Drop (http://forums.pelicanparts.com/porsche-911-technical-forum/1083579-first-engine-drop.html)
Pedro '84 Coupe 01-29-2021 07:24 AM
Originally Posted by Funracer (Post 11201289)
Purchased this today. Funny I check the parts for sale section every day and missed that. A few of the bits are missing from what he has for sale but all of those look to be available on PP.
I know I am taking a risk buying used but these are original Porsche parts and according to most people the failure rate on these tensioners is extremely small.
Thanks again for the tip!
No problem! Hope it works out for you http://forums.pelicanparts.com/suppo...s/beerchug.gif
gomezoneill 01-29-2021 03:48 PM
If you're going this far I would suggest you pull the heads and cylinders replace the timing chains valve job etc...
The chains look stretched that means the gears are worn. With all the work your going through you may as well go through it all. It is a slippery slope.
Funracer 01-29-2021 04:24 PM
Not planning on that until it gets to 250,000 miles. Or I find something that makes me do it, whichever comes first.
Funracer 02-09-2021 10:23 AM
Pulled the valve covers today and carefully torqued all the head studs to 23lbs. Many of them were loose-ish so I’m am glad I did it. Hopefully this will eliminate another source of leaks.
Should I also torque the cam housing bolts while I am there or no? The How to Modify and Build Porsche Engines book says this can be a source of leaks.
Lastly, good news on the rocker seals, I think. The areas are dry that should be (see photo). There may be a slight walking on one of the rocker shafts (see photo) should I try to reposition it to leave it since its not leaking? Planning to re-torque the rocker shaft Allen bolts when I do the valve adjustments.
http://forums.pelicanparts.com/uploa...1612894854.jpg
Compared to this one:
Thanks for any advice
ADDvanced 02-13-2021 09:11 AM
I would still do RSR seals. Costs not much, just an hour or two of labor, and then you'll have even fewer places to leak.
Funracer 02-13-2021 02:56 PM
That’s a tough one for me. Not leaking a drop currently.
Is RSR a brand name? Does PP sell them?
Eagledriver 02-14-2021 08:49 PM
If they aren’t leaking, don’t touch them. Fix them one at a time if they start to leak (they probably won’t). If you disturb them some will almost certainly leak.
ADDvanced 02-15-2021 06:29 PM
If they're 100% bone dry, yeah I guess, but they're so cheap and easy to do with the engine out right now.
Flojo 02-16-2021 02:28 AM
I double that!
proporsche 02-16-2021 04:52 AM
if the shaft is not leaking do not bother---old saying is..if it ain`t broken why fix it......
Ivan
Mr Beau 02-16-2021 09:26 PM
I used RSR seals *and* wicking Loctite when assembling my (still unfired) engine.
Funracer 02-17-2021 01:20 PM
I think I will leave shafts alone for now and keep an eye on them whenever I have the VCs off.
Thanks for all input.
911SauCy 02-19-2021 10:37 AM
Definitely torque cam housings
Funracer 02-19-2021 08:04 PM
Cool! Will do.
Quasimoto 02-20-2021 03:53 AM
PMFJI, are you guys talking about the mounting fasteners or just the covers?
Funracer 03-08-2021 08:03 AM
I did. None of them moved a bit.
Funracer 03-08-2021 08:14 AM
http://forums.pelicanparts.com/uploa...1615219398.jpg
SnapGap kit is wonderful. I set my valves with feeler gauge last summer with engine in the car. Took hours.
Reset them on the engine stand yesterday with the SnapGap kit. Never used it before. In total it took 40 minutes. I wiggled each rocker to get a before-and-after feel. My guess is they were at about .2mm prior to the SnapGap procedure (twice what they should have been). Now they are at .1mm for sure.
Of course being on the engine stand helped a lot as well, but some tools are just worth the time and hassle saved. And no cursing!
yelcab1 03-08-2021 09:17 AM
I gotta try that Snapgap thing one of these days. But … I gotta tell you, wiggling the rocker and arriving at 0.2mm guess is just that, highly inaccurate guess.
Funracer 03-08-2021 07:53 PM
Yes just a guess, as I said. May have been .25mm:)
Funracer 03-12-2021 10:02 PM
Installed oil fed tensioners and am putting in the other bits and pieces to finish this upgrade. Only problem with the parts I have assembled so far:
http://forums.pelicanparts.com/uploa...1615614739.jpg
Any reason not to drill and tap a TT switch port in the left chain cover (might be time to buy a drill press)? I have a tap and die set but not one this large. I believe the TT on the left side chain cover and 15 degree switch on the right are the same threads. Offhand anyone know what size tap to buy?
Looked for a left chain cover that has both the tensioner oil line port and the threaded port for the TT switch but could not find one outside of a full kit.
