Engine adapter which side
I removed my exhaust crossover pipe and now my adapter fits flush on either side.
Almost all the picture I see have this type adapter mounted on the passenger side trans bolts. If I mount mine on the drivers side (as in the picture here) will it interfere with anything during disassembly or reassembly? Just want to have good access to my oil cooler.
As per suggestions from others I am planning to remove the clutch prior to mounting the yoke.
Old 01-28-2021, 07:20 PM
Passenger side if it's a teardown. Flywheel off too to get at the nuts under it.
206 637 4071
Old 01-28-2021, 07:26 PM
Yup, mount it on the other side. It'll make it easier when you put the case back together.
Old 01-28-2021, 07:39 PM
Not planning on opening the engine. I hope!
Can I easily access the oil cooler if its on the passenger side?
Any tips on get a stuck pressure plate off?
Old 01-29-2021, 07:05 AM
Really hoping I do not have to open the case. Just doing leak repair mostly.
Old 01-29-2021, 07:06 AM
Just did this (complete reseal, no case opening) - had mine in same place you did and it worked great
Old 01-29-2021, 01:17 PM
Thanks so much. Can’t wait to get started!
Regards
Old 01-29-2021, 01:56 PM
Prestallion's Avatar
What brand engine adapter is that in your photo?
Old 01-30-2021, 06:57 PM
Originally Posted by prestallion View Post
what brand engine adapter is that in your photo?
qsc
Old 01-30-2021, 09:45 PM
