Engine adapter which side
![]() I removed my exhaust crossover pipe and now my adapter fits flush on either side. Almost all the picture I see have this type adapter mounted on the passenger side trans bolts. If I mount mine on the drivers side (as in the picture here) will it interfere with anything during disassembly or reassembly? Just want to have good access to my oil cooler. As per suggestions from others I am planning to remove the clutch prior to mounting the yoke. Thanks |
Passenger side if it's a teardown. Flywheel off too to get at the nuts under it.
Yup, mount it on the other side. It'll make it easier when you put the case back together.
Just did this (complete reseal, no case opening) - had mine in same place you did and it worked great
Thanks so much. Can’t wait to get started!
Regards |
What brand engine adapter is that in your photo?
