LinkBack | Thread Tools |
Rating:
you snake the wire and feed it into the original switch connector at the M/C ? So, you'd also need additional spade adapters and longer wires. Interesting alternative, but I am not a fan of aftermarket wires running throughout the car. Makes things confusing for the next owner.
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 03-23-2021 at 05:40 PM.. |
Forget the pedal, easiest way is to mount the mechanical switch on the master cylinder. Tons of information here on various mounting methods.
Walt 82SC 3.0 81SC 3.6 |
swapping out the brake light switches is a job that I still have nightmares about, almost 4 years later. the original switches made it almost 25 years, hopefully the replacements make it that long.
'83 SC Targa '87 944 Turbo '08 Cayman '10 Boxster S |
The factory put in two switches for redundancy. The fact that the both get old at the same rate just means you need to likely replace them every 25 to 30 years as maintenance. It is not that hard to do, and sure beats some home made bodge. The factory moved away from the pedal mounted switch for a reason. On my 914 I had to replace that switch twice because of getting in the car with wet feet and the pedal area is a dirty area.
If an old fat man like me can replace them fairly easily, anyone can. It is your car, do to it what you want, but check your brake light function regularly regardless what system you go with.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Ordered a cheap switch for $8.
It matched the part better than the ATE brand Correctly sized 22mm, so I got it installed easily. Verified the brake lights now work again with a light touch. I now have one brake light switch, and the car is back on the road.
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 03-25-2021 at 04:11 PM.. |
Touchdown!
Air bubbles stayed away?
A little bit of fluid dropped out onto the catch rag.
Brakes light up with barely any pressure. Brakes work fine, but I'll flush the fluid in the Spring.
1986 Bosch Icon Wipers coupe. |
I went through this (twice!) with my '84. The second time, I took apart the switches and found the contacts quite damaged due to arcing. When I put the second set of switches on, I added a relay to protect them. There are several threads on the problem here, if you're interested.
There are 2 switches to carry the amperage of the brake lights from what i understand. The switches are rated at 6amps? I think that one switch will fail sooner than 30 years.
I used a Dremel around the outer edge of the case to free up the switch guts.
It's a pretty common problem as the cars age https://forums.pelicanparts.com/porsche-911-technical-forum/422337-anyone-hear-about-solution-failed-brake-light-switches.html#post4087694 |
Subscribed.
Following along as this is next on my "to-do" list. I am in the process of trying to make the Cruise Control unit in my 1982 911sc function.
Just noticed that my brake lights do not light up anymore.
I need to revisit. Last time in 2021, I only replaced one switch. Could it have failed already? I barely ever drive the 911 the last few years. Could the switch be stuck? Can I remove and jam a pick in there? Could there be an air bubble at the switch?
Which fuse is for brake light? I should check that also
Diagram for 86 Coupe shows this is fuse number 4 (8A) on fuse box I. Should be a green/blue wire.
Gilles RoW 88 Carrera coupé |
https://imgur.com/a/p0rGOjM My fuse is intact. I will order a new switch
