LinkBack Thread Tools Rating: Thread Rating: 5 votes, 2.60 average.
sugarwood's Avatar
Originally Posted by 911pcars View Post
There’s a large variety of mechanical switches, all adjustable depending on actuation distance. Install in any convenient location in the pedal actuation system. The brake pedal and link to the MC are often used locations.
https://www.amazon.com/universal-brake-light-switch/s?k=universal+brake+light+switch&page=2&qid=1616524224&ref=sr_pg_2
7[/url]
Once you mount the aftermarket switch at the pedal,
you snake the wire and feed it into the original switch connector at the M/C ?
So, you'd also need additional spade adapters and longer wires.
Interesting alternative, but I am not a fan of aftermarket wires running throughout the car.
Makes things confusing for the next owner.
1986 Bosch Icon Wipers coupe.
Old 03-23-2021, 05:35 PM
walt's Avatar
Forget the pedal, easiest way is to mount the mechanical switch on the master cylinder. Tons of information here on various mounting methods.
Walt
82SC 3.0
81SC 3.6
Old 03-23-2021, 06:00 PM
Originally Posted by sugarwood View Post
That blade is wider than the gap between the prongs.
Since you had to saw diagonally, I am guessing you were not able to cut it flush?
No seatment issues ?
It fits and I filed the rest.
Nope...
Old 03-23-2021, 08:16 PM
swapping out the brake light switches is a job that I still have nightmares about, almost 4 years later. the original switches made it almost 25 years, hopefully the replacements make it that long.
'83 SC Targa
'87 944 Turbo
'08 Cayman
'10 Boxster S
Old 03-24-2021, 08:17 AM
The factory put in two switches for redundancy. The fact that the both get old at the same rate just means you need to likely replace them every 25 to 30 years as maintenance. It is not that hard to do, and sure beats some home made bodge. The factory moved away from the pedal mounted switch for a reason. On my 914 I had to replace that switch twice because of getting in the car with wet feet and the pedal area is a dirty area.
If an old fat man like me can replace them fairly easily, anyone can. It is your car, do to it what you want, but check your brake light function regularly regardless what system you go with.
Old 03-24-2021, 12:09 PM
Hard to disagree with?
Old 03-24-2021, 06:44 PM
sugarwood's Avatar
Ordered a cheap switch for $8.
It matched the part better than the ATE brand
Correctly sized 22mm, so I got it installed easily.
Verified the brake lights now work again with a light touch.
I now have one brake light switch, and the car is back on the road.
Old 03-25-2021, 04:03 PM
Touchdown!
Old 03-25-2021, 05:16 PM
Air bubbles stayed away?
Old 03-25-2021, 05:58 PM
sugarwood's Avatar
A little bit of fluid dropped out onto the catch rag.
Brakes light up with barely any pressure.
Brakes work fine, but I'll flush the fluid in the Spring.
Old 03-25-2021, 06:43 PM
That's good, mine drained out, I lost half a 'tank.'
Old 03-26-2021, 07:31 AM
I went through this (twice!) with my '84. The second time, I took apart the switches and found the contacts quite damaged due to arcing. When I put the second set of switches on, I added a relay to protect them. There are several threads on the problem here, if you're interested.
Old 03-26-2021, 08:59 AM
There are 2 switches to carry the amperage of the brake lights from what i understand. The switches are rated at 6amps? I think that one switch will fail sooner than 30 years.
Old 03-26-2021, 11:54 AM
sugarwood's Avatar
How did you take apart the switch? I'd like to take apart my old one.
Old 03-26-2021, 01:21 PM
I used a Dremel around the outer edge of the case to free up the switch guts.
It's a pretty common problem as the cars age
https://forums.pelicanparts.com/porsche-911-technical-forum/422337-anyone-hear-about-solution-failed-brake-light-switches.html#post4087694
Old 03-26-2021, 02:04 PM
_sponge_'s Avatar
Subscribed.
Following along as this is next on my "to-do" list. I am in the process of trying to make the Cruise Control unit in my 1982 911sc function.
Old 07-28-2021, 02:07 PM
sugarwood's Avatar
Just noticed that my brake lights do not light up anymore.
I need to revisit. Last time in 2021, I only replaced one switch.
Could it have failed already? I barely ever drive the 911 the last few years.
Could the switch be stuck? Can I remove and jam a pick in there?
Could there be an air bubble at the switch?
Old 06-27-2024, 07:37 PM
sugarwood's Avatar
Which fuse is for brake light? I should check that also
Diagram for 86 Coupe shows this is fuse number 4 (8A) on fuse box I. Should be a green/blue wire.
Gilles
RoW 88 Carrera coupé
Old 06-28-2024, 06:54 AM
sugarwood's Avatar
No, it is fuse #7
https://imgur.com/a/p0rGOjM
My fuse is intact.
I will order a new switch
Old 06-28-2024, 05:59 PM
