Windshield Re-installation: use sealant or not?
After a dash restoration on an 84 3.2, I’m looking to have the original windshield reinstalled along with a new OEM moulding purchased here.
After calling a couple of glass shops, some use some sort of sealant and some not. My thought previously is to not use sealant with new moulding, which is supposed to seal properly on prepped surfaces; but perhaps time has moved on with best practices.
Any thoughts in this forum regarding the proper way to re-install a front windshield?
Old 04-05-2021, 10:43 AM
porsher
aston@ultrasw.c's Avatar
for the OEM molding, no sealant is required
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 04-05-2021, 12:13 PM
walt's Avatar
No sealant. I think some of the later 911's either 964 or 993 require sealant.
Walt
82SC 3.0
81SC 3.6
Old 04-05-2021, 12:33 PM
Thank you for confirming!
Old 04-05-2021, 01:23 PM
Only seal if it leaks. Usually doesn't. Mould some 3M strip caulk in the corners ahead of time so the seal corners don't fall in.
206 637 4071
Old 04-05-2021, 02:24 PM
Thanks.
Old 04-07-2021, 09:15 AM
Flojo's Avatar
whenever I install Glass/Windschield on a 911 (and on my previous vintage cars) I seal it with a special Teroson sealant all arount.
Using a very small opening on the the tip of the cartridge.
Going around below the lip touching body and going around below seal touching glass.
Especially on the windschield! regardles of using an OEM-Porsche-bought rubber seal.,
Doing so I always had absolute waterproof glass installed.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 04-07-2021, 10:34 AM
Flojo: curious, have you ever removed a windshield after you added this sealer? Thanks
Old 04-07-2021, 11:56 AM
Now in Florida !
Location: York Beach, Maine and Anastasia Island, Florida
Flojo - which specific Teroson sealant do you use?
1983 911SC Coupe Hot Rod - Platinum - Twin plugged 3.4, DC-60 cams, PMO 50's, 1 3/4 headers, Bill Rader 915 w/LSD
1976 914 2.0 Lime Green Metallic - Completely stock
Old 04-07-2021, 01:30 PM
LJ851's Avatar
John, are you putting the strip caulk on the outside edge of glass in the corners to keep the seal pushed towards the body of the car? Or between the seal and body ?
Old 04-07-2021, 01:56 PM
AutoBahned
RWebb's Avatar
I let the glass shop do this with a seal from the dealer. They get to decide and I hear different pro shops vary in sealant vs. none.
Old 04-07-2021, 02:38 PM
Seal and body. You see a lot of that after the old seal is out. Used to be standard practice. I still do it.
206 637 4071
Old 04-07-2021, 03:07 PM
I have been a window (some automotive glass) guy for years and years. Yes, sealant can be an "extra level of protection", but good luck trying to remove anything bedded in sealant. $5.00 says it will never come out in one piece
Old 04-07-2021, 03:08 PM
