Lubricant for Reinstalling Injectors
What say you all re: lubricant that should be used on injector o-rings when reinstalling in a 3.2 Carrera? Silicone paste? Molykote? Other? Thanks!
Old 04-21-2021, 02:54 PM
proporsche's Avatar
Sachs lubricant works the best
https://aftermarket.zf.com/remotemedia/migrated/services/workshop-service/import-brands/technology-in-practice-1/fatcushion-tube-zoom-zf_w960.jpg?v=101070070
1985 911 with original 502 191 miles...808 198 km
Old 04-21-2021, 02:59 PM
Much appreciated. Appears to be available from our host and so I'll pick up a tube.
Old 04-21-2021, 03:05 PM
Silicone paste, just a light smear.
206 637 4071
Old 04-21-2021, 03:23 PM
WD40 works for me.
Old 04-21-2021, 05:50 PM
theiceman's Avatar
silicone paste. manual just says soak them in gas..
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 04-21-2021, 06:05 PM
WD40, synthetic grease, KY, olive oil, dish soap ... whatever you have kicking around.
John
Old 04-22-2021, 03:19 AM
Flojo's Avatar
dish soap. always at hand, for sure doesn't attack rubber, vanishes by itself
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 04-22-2021, 04:07 AM
walt's Avatar
All of the above plus Dow 111 specifically made as an o-ring lube. You can find small tins of this online for not to much $$.
Walt
82SC 3.0
81SC 3.6
Old 04-22-2021, 04:33 AM
But isn't silicone supposed to be harmful to sensors? O2 sensor maybe? Ordinary grease may be the safer alternative.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 04-22-2021, 05:00 AM
Wildman Emeritus
I soaked mine in gas per the manual and they went in with no issues.
I think any of the suggestions above will work just fine.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 04-22-2021, 05:09 AM
Got my '84 3.2L injectors back from RC Fuel Injection - the report is pretty interesting (although -- for some reason -- my wife did not find it nearly as interesting as I did -- go figure). It clearly shows that the injectors were sorely in need of service:
My question to the group is, once the injectors and rails are re-installed, is there a start-up protocol that should be followed given all the air in the fuel system? Or do you just crank it until it fires up?
Old 05-10-2021, 09:32 AM
Brew Master
cabmandone's Avatar
When I put mine in after cleaning I just hit the key. Don't know if that's right or wrong but it worked. Now, I'd probably wait a few seconds since my car has a tune that runs the pump for a few seconds to prime the system. If you really want you could install the injectors and put a jumper on the fuel pump fuse to run the pump for a few seconds and prime.
To your original question, I think I used some Sil glyde when I installed my injectors.
BTW, I don't know why wives don't find that stuff as interesting as we do.
Nick
Old 05-10-2021, 09:41 AM
Still here
pmax's Avatar
Whew, good to know ... cause that’s what I used on the CIS injectors.
Old 05-10-2021, 10:57 AM
