Got Boost?
IMONBOOST's Avatar
Question EGT owners, HELP - wire length problem
I bought an EGT Gauge from Auto Meter (Sport-Comp). The Gauge comes with an 8 foot wire/cable to connect the gauge to the probe. The instructions state that the length of the cable may not be increased or decreased because the reading will be compromised. I guess the wire has a specific resistance for the calibration of the gauge.
What are the options here?
Are there longer cables that will not compromise the reading?
I haven't called Auto meter since I bought the gauge from a friend and decided to ask here first.
"The only motivation to make you go race after race, travel after travel, is winning. The possibility that you have for winning. If you don't have that, nothing else can make you work."
-Ayrton Senna-
Old 05-03-2003, 07:15 PM
Early_S_Man's Avatar
Porsche Crest
I assume that the sensor is a Type K or Type J thermocouple. The leads can be extended if you use the proper type of matching thermocouple wire ... just don't try to use ordinary copper wire! Try a local HVAC supplier ... they should be able to sell you however many feet of additional Type K, or Type J thermocouple wire you need ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 05-03-2003, 07:47 PM
Got Boost?
IMONBOOST's Avatar
How can I tell if it is a type-K or type-J thermocoupe? I just spent some time on the web and I could always find that the Autometer EGT gauge that comes with an external module uses the type-K, but I could not find the type for the gauge that I have which does not use an external module.
-Ayrton Senna-
Old 05-04-2003, 03:57 AM
I'm not too up on all the compatibility issues of type K thermocouples. If they have the same connector design, Fluke (manufacturer of digital meters) sells type K thermocouples. They also have a type K harness kit to extend the reach of their thermocouple sensor. Not too expensive but not sure what you and they have are compatible. Check the Fluke website for pics and info.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 05-04-2003, 11:07 AM
Cool
there may be a specific type of solder involved.............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-04-2003, 07:12 PM
Silver solder.
Sherwood
Old 05-04-2003, 08:07 PM
Cool
Originally posted by 911pcars
Silver solder.
Sherwood
not sure if that was the issue w/EGT wire.. had something to do w/ the high nickel of the wire.. maybe it was the use of zinc chloride flux............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-04-2003, 08:37 PM
The shop that repaired my type K thermocouple said they used silver solder. Not sure about the EGT wires in your setup.
Sherwood
Old 05-04-2003, 08:52 PM
Got Boost?
IMONBOOST's Avatar
According to the Autometer installation manual solder should not be used because it affects the calibration. Maybe they assume the general public will not be using Silver solder?
-Ayrton Senna-
Old 05-05-2003, 04:55 AM
Irrationally exuberant
ChrisBennet's Avatar
Until the real brains weigh in on this, this is my take on it:
I don't think it is the resistance of they are worried about. A thermocouple wire is just two different metals ("dissimilar metals") sandwiched together or even just wrapped around each other. When you heat them, they produce a small current. If you connect these wires to some other kind of wire you have produced another a junction between two dissimilar metals i.e. another thermocouple. This would be sort of like using a battery for one of your sensor wires; it's going to throw your measurements off.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-05-2003, 06:10 AM
Got Boost?
IMONBOOST's Avatar
So far I still have the problem that I don't know wether I have a K-type or J-type thermocouple. Once I figure this out, my guess is it should be fine as long as I buy thermocouple extension wire for the correct type of thermocouple as Warren Said.
-Ayrton Senna-
Old 05-05-2003, 07:41 AM
Cool
Sherwood
I have a JPI unit on order.. the JPI tech said I could entend the connectiing wire a LIMITED length by DIY soldering.. so I had them do the 15ft harness extension.. I kinda picked up that it was a sensitive solder job.. and he stressed that I use the engine ground for the instrument computer.. probably to maintain the same grounds as the K probes.. the K probes are grounded in this type of system/maybe all probes are grounded, don't know.........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-05-2003, 07:51 AM
