modifying console for much easier install/removal
I have a 86 3.2 Targa, and removing the center console is a real pita. When there is factory AC it's even more complicated. Getting all the controls, switches and cable booms in and out is a nightmare. First time I did this it took me the best part of a day to remove and install back in. And my hands had scratches all over.
Cause all was out again for replacing carpets, I thought this was the time to fix this. It actually worked out great, with this (easy) mod I don't need more than 15 minutes to get the console out and back in.
This is the console I am talking about
Removing it is a lot of work, once here it's easier.
Removing the plastic frames is a matter of some screws
one of the problems is that all cable booms go upwards through a horizontal opening and then flat to the back again. The cables obstruct everything and are the cause of the fiddling.
comes in the saw to cut off the whole back.
Now we take a look at the back of the console frame (back cover off). The passage for the wiring looms and AC is limited in size
So, I simply made it (much) bigger
Now we return to the frame, and install the switches and the leads.
The empty console chassis is put back loosely on the tunnel. The AC switches are simply pushed through the (now hughe) open rear.
The frame is now pushed in, it became a piece of a cake to install the AC switches. The frame is fixed into the chassis with 1 OEM top screw each side. Putting two extra self tapping screws at the bottom (about where the central locking is) fixes everything firmly
It does not take more than a couple of minutes to go through the steps in the last 4 pictures. And no scratches on my hand!
Old 04-30-2021, 05:09 AM
When the back cover is slipped over, nothing of all this mods is visible. And I have a lot of peace of mind in case I need to remove it all again, and I will cause I will upgrade the AC ;-)
Old 04-30-2021, 05:11 AM
Porsche Addict
Nice write up, and very good looking carpet too!
Lawrence - 1986 911 Carrera Coupe Grand Prix White
1959 Land Rover Series II
1962 Volkswagen Sedan Ragtop
1959 Porsche 356A Coupe
1971 Porsche 911T coupe
Old 04-30-2021, 08:11 AM
RFP RFP is offline
RFP's Avatar
Excellent project and write-up! Thanks! This is a real improvement with no particular 'downside.'
By the way, I love your square weave carpet.
Maverick Region PCA, Fort Worth/Dallas area
1987 911 Coupe, Black M491 3.4 // Turbo-Look Registry # 1249
1977 911 Coupe, Metallic Sienna (I think!)/Lobster SOLD
1982 924 White, SOLD long ago
1966 912 Red, SOLD, totaled a week later by its new owner
Old 04-30-2021, 10:43 AM
Thank you for the tip. I agree about the console being a PIA to take out & put back in. Will do this mod next time I get in there.
Old 04-30-2021, 04:54 PM
