modifying console for much easier install/removal
I have a 86 3.2 Targa, and removing the center console is a real pita. When there is factory AC it's even more complicated. Getting all the controls, switches and cable booms in and out is a nightmare. First time I did this it took me the best part of a day to remove and install back in. And my hands had scratches all over.
Cause all was out again for replacing carpets, I thought this was the time to fix this. It actually worked out great, with this (easy) mod I don't need more than 15 minutes to get the console out and back in. This is the console I am talking about Removing it is a lot of work, once here it's easier. ![]() Removing the plastic frames is a matter of some screws ![]() one of the problems is that all cable booms go upwards through a horizontal opening and then flat to the back again. The cables obstruct everything and are the cause of the fiddling. ![]() comes in the saw to cut off the whole back. ![]() Now we take a look at the back of the console frame (back cover off). The passage for the wiring looms and AC is limited in size ![]() So, I simply made it (much) bigger ![]() Now we return to the frame, and install the switches and the leads. ![]() The empty console chassis is put back loosely on the tunnel. The AC switches are simply pushed through the (now hughe) open rear. ![]() The frame is now pushed in, it became a piece of a cake to install the AC switches. The frame is fixed into the chassis with 1 OEM top screw each side. Putting two extra self tapping screws at the bottom (about where the central locking is) fixes everything firmly ![]() ![]() It does not take more than a couple of minutes to go through the steps in the last 4 pictures. And no scratches on my hand! Last edited by alexandervdr; 04-30-2021 at 08:39 AM.. |
When the back cover is slipped over, nothing of all this mods is visible. And I have a lot of peace of mind in case I need to remove it all again, and I will cause I will upgrade the AC ;-)
Porsche Addict
Nice write up, and very good looking carpet too!
Lawrence - 1986 911 Carrera Coupe Grand Prix White 1959 Land Rover Series II 1962 Volkswagen Sedan Ragtop 1959 Porsche 356A Coupe 1971 Porsche 911T coupe |
Excellent project and write-up! Thanks! This is a real improvement with no particular 'downside.'
By the way, I love your square weave carpet.
Maverick Region PCA, Fort Worth/Dallas area 1987 911 Coupe, Black M491 3.4 // Turbo-Look Registry # 1249 1977 911 Coupe, Metallic Sienna (I think!)/Lobster SOLD 1982 924 White, SOLD long ago 1966 912 Red, SOLD, totaled a week later by its new owner Last edited by RFP; 04-30-2021 at 01:31 PM.. |
Thank you for the tip. I agree about the console being a PIA to take out & put back in. Will do this mod next time I get in there.
