Directionals not working
Now when I go to put my directional on nothing happens. The arm for the directional seems to work fine for left and right, and the high beams work, but when I go to use the directional nothing happens not even the left or right arrows on the dash. Is there a relay or switch for them? Or is it the switch in the steering column that needs to be replaced?
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip One Way To Get More Horsepower Is To Get A Bigger Horse! "I couldn't find the sports car of my dreams, so I built it myself" Ferdinand Porsche |
have you twisted your fuses yet?
when you see hoof prints, dont automatically assume zebras |
Tom, Did you try the 4 way flasher switch to see if the flashers will work at all? If I remember correctly, the flasher relay is in the dash behind the gas guage. If I'm wrong, someone please correct me. Craig
80SC |
I would rather be driving
Do the lights come on and not flash?
Lights on no flash - check the flasher behind the gas guage. No lights at all check the fuses or grounds to lights.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Went back out and tried the four way flasher(emergency flasher) and nothing. All my parking lights work. When I hit the lever for my directionals there is absoulutely nothing. So I guess I'll try to find the flasher relay behind the fuel guage. Thanks guys.
Tom
ON my car the TS would stick. I took out the flasher relay and cleaned the contacts on the inside. You can see how the outer cover pops off. simple magnetic circuit with an RC time delay. Just clean the contacts and you should be back in business. Of course, you can buy a new one as well.
69 911s you got it. One thing I've learned with these cars is when something is not right always check the easy things first. The fuse was fine but when I went back and gave it a little twist everthing started working again. Thanks everyone for all your help.
Tom
Emanuel
"Motorcycles... the cigarettes of transportation." Seth Myers |
well somebody circle this day on the calendar, I finally got one right...
Hey 69 911s,
Even a blind squirrel gets a nut now and then. Just kidding, Again thanks you saved me alot of hours of searching, I owe you one. Tom
Thread Tools | |
Rate This Thread | |
