3.2 bogs down doesn't have full power
So I've read through several threads about this and most don't seem to apply to my situation. The quick rundown: 1988 backdated 3.2. The car is new to me and I'm a new Porsche owner. Car ran great when I purchased it, drove it home 350 miles with no issues. I changed the oil cooler flexible lines, did a valve adjustment, changed the oil, filter, spark plugs and fuel filter, air filter, DME replacement (focus9 upgrade). The car has SSI exhaust and I found the O2 sensor unplugged when I was poking around so I plugged it back in. Shortly after doing the above maintenance the car seems to bog down or not have full power at times. The idle seems rougher to me too. While driving along at a constant speed the car will suddenly increase increase speed and run much better. To me it feels like a fuel supply or spark problem but, again, I'm a new owner.
Thoughts? Thx!
1988 911 Carrera Targa ROW |
disconnect the oxy sensor
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Brew Master
Nick Last edited by cabmandone; 05-19-2021 at 03:23 AM.. |
I've not seen this before.
Pelican thread on it: Solid state DME Relay conversion ? Solid state DME Relay conversion ? Solid-State DME Relay 84-89 911 https://rennlist.com/forums/911-forum/947925-solid-state-dme-relay-84-89-911-a.html ![]() Just tossing this out there, mismatched rotor as in using a resistor type when you need an non-resistor type because of aftermarket upgrade (MSD) is a common mistake. Also not replacing the distributor cap and be a mistake, hairline cracks can form out of nowhere. I don't know squat about this relay, but going back to what was in the car before sounds like a solid approach. Wrong spark plugs, wrong gap, and or pulling on ignition wires and causing damage to them can happen even with the best of intentions and being careful. I once chased a problem for a week on my S10 pickup truck, air intake hose slippage after air cleaner replacement, it can be the simple things.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 05-19-2021 at 01:38 PM.. |
if you have never adjusted your C/O level maybe you should go and have it checked...
Ivan
Thanks all for the replies. Yes, I meant the DME relay...my original one died so I "upgraded" to the FT9 solid state one. I'm going to hope that is not the problem because I don't have another to swap in there. Good thought on the dizzy cap, I will get one of those and swap that our as well as the plug wires. Before doing those I'll unplug the O2 sensor. Also, I unhooked the battery last night as I read somewhere that might reset/recalibrate the computer. I'll report back once I go through these fixes. Ivan, what do you mean by the C/O level...carbon monoxide out the exhaust? Thx.
yes you fuel air mix ratio..C/O level..it could be rich ...
Ivan
Alright! Just took the car for a 1/2 hour spin and it was fine! It was either disconnecting the battery for a computer reset or unplugging the O2 sensor. I'm going to guess the O2 sensor was the problem. So now, apparently the sensor is not needed? Any negative effects to just leave it unplugged? I don't have to do emissions testing or anything where I live.
Also, how do I tell if the DME has been "chipped" and the O2 sensor is not needed? The previous owner didn't seem to know much about the car (based on a lot of "I don't know" when I bought it from him). If I had known more before I bought it I would've had an inspection done but the car looks awesome and, now, runs great and pulls hard.
Brew Master
On a 3.2 it is more commonly referred to as the base idle mixture. But if it ran fine for a 350 mile trip, the base idle mixture didn't suddenly change.
Nick |
Brew Master
Nick Last edited by cabmandone; 05-19-2021 at 04:02 PM.. |
I believe the ROW carrera did NOT have a O2 sensor. PO put it there.
Interesting...the harness certainly looks original but I guess the ROW could've had the same harness and he just added the plug.
it all depends where is the car from ROW..mine is Euro model and it came with the catalyst and the oxy sensor.i do not use it at all i bypassed the circuit on my computer with a switch and remove the cat....if i go to France for smog test i put it on .....if you do not need it for your place where you live do not bother connecting it;-)
In France the ROW 911 have the cat and oxy sensor..... Ivan
