78 SC Targa
911SC. Problem with old vs new ignition switch assembly
Hi all, after an attempted theft of my '77 SC, the ignition was damaged so I've purchased a new lock set.
The original part is 91161301101, the newer replacement part is 96434701701. My mechanic says the new one doesn't fit, that's it's too long and hits the bulkhead. But the part is the replacement recommended by PP and Porsche. Has any one had any experience of replacing the old with the new?
it should fit without any problem if your mechanic knows how to put it in...
Ivan on another note i would buy the old one from you if you like..?
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
78 SC Targa
I'll be selling the old one eventually but the tumbler is damaged with something jammed in it from the attempted theft. |
I installed a new ignition switch (mechanical & electrical) and it fit but I did have to remove all of the steering column bolts.
just make sure he removed the security bolt(allen insert tool) completely..also the dash plate s off?where the original rivets were?No need to install the rivets at all. just 2 allen head screws to hold it in place...
I know it is bad tumbler -i would not have problem with that.
78 SC Targa
Thanks! |
No such car as a 77 sc. Sc 78-83
78 SC Targa
if it is 77 late it is consider 1978...that what everyone will call it;-)nice to have ..had one too sold it back in LA to France;-)is your black?
Ivan
acrylic .i`ve sent you a PM on right top corner ..
Ivan
| Tags |
| ignition lock |
