check, measure adjust question
I was reading through the check measure adjust manual and there is a note in it about if you run a 72 or 73 engine on gas that is "98 octane" then you will have a high CO content. I currently run premium(93) in my 73T. When I go to do check measure adjust will this throw off the readings?
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
PRO Motorsports
Yes it will. The ultra-low compression of your engine makes premium fuel unnecessary. Like it states, higher octane fuel is harder to ignite in a low compression engine. Your car will actually run better on regular.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Bandwidth AbUser
Tim, we run only regular in Lu's 73E. Like Tyson says, premium fuel is unnecessary...even after you upgrade your 73T to 2.7RS specs.
Jim R. |
hehe but what about a 2.7 RS with a 9.8:1 C/R
![]() Thanks for the reply guys!
