CIS without the computer
Can I get the CIS system to run without the computer? I have a 3.0 engine, 930/03 without a CIS system. I found a system for a Lambda equipped engine but I do not have the computer for it. Is it possible to get to work?
Sigurd 73.5T 3.2SS EFI X87 944S 3.0 |
930/03 Engine........
Sigurd, The 930/03 motor did NOT come with the lambda system. You need to look for ‘78~’79 CIS unit with 39-mm intake runners (-4R), WUR-045/-069, FD-031, and other related CIS components. Tony Last edited by boyt911sc; 10-02-2021 at 11:55 AM.. |
ROW '78 911 Targa
Tony, you forgot the word NOT between did and come in your first sentence…
The rest of your post is correct as usual. He needs a 78/79 CIS system with the larger diameter runners. The US Lambda CIS systems are not compatible with the 930/03 engine.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 10-02-2021 at 11:02 AM.. |
Good eye......
Thanks for catching the mistake. Tony |
Sigurd - You might think about replacing the CIS with an EFI ITB kit (since you are starting with nothing) if your local regulations allow it.
I know - heresy from a CIS lover - but if starting from scratch, then I do think that EFI is the way to go now... |
ROW '78 911 Targa
Noticed you are in Norway.
Any CIS system from a European engine will work from 78 to 83 on your 930/03. Just not the US/CDN/Japan Lambda systems.
