Problem seating springplate rubber
Hi guys,
Ik need some help from the "allmighty knowledgebase" I've recently replaced my springplates (with new rubbers) but somehow the rubber keeps bulging from the rear torsion plate covers. Is this normal and will the rubber seat when driving or am I doing something wrong? Kind regards, David
1973 2.4 MFI bone-stock 911T |
Following.
Sent from my iPhone using Tapatalk |
1979 911 SC
I just finished this awesome video on Youtube about this procedure. If you forward to the end you can see his finished product and as far as I can tell there is no bushing visible around the torsion bar cover. Hope this helps.
https://www.youtube.com/watch?v=MaqwQRMpndI&list=PLkWFofpgz2Og6nqijrJAFz7MB_vVCU9Vp&index=2 |
Thanks, excellent video.
For sure not normal. What was the rubber and how did you prepare the plates?
1982 911SC |
Location: behind the redwood curtain, (humboldt county) california
Manufacturer and lube >>
Hi Dave,
A couple of questions, Who made the bushings?? and what did you use to assemble the bushings to the chassis/cover?? chris |
Springplates and rubbers are from dansk I believe. I put the covers on with lots of soap en tightened the bolts a few turns at a time each
Still have the original (non ajustable) spring plates. Maybe I should give them a try
Did you super glue the bushings to the spring plate tubes first?
The rubbers came pre-attached ![]()
That does look odd. I did this job years ago and searched far and wide to find a glue that actually worked, found some esoteric 3M adhesive that was supposed to work on steel and rubber under extreme conditions. It didn't, the first time I drove it in really cold weather the adhesion broke and I got low squeak over bigger bumps. I've gotten to where I ignore it...maybe I should have just used super glue. Since yours came pre attached maybe they will stick.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
I’ve tried to to tighten the bolts several times and never noticed loose rubbers
Are the outer retainers original or aftermarket?
All aftermarket john
Try your original for the hell of it.
I'll do that. I will keep you posted.
thank you all for your input.
Are spacers needed between the threaded mounting bosses and the retainers? It's been a while, for me, but I recall that I needed 4-5 mm spacers to make the adjustables fit an early (this is a 1973?) car. Cylinder head washers did the trick, as I recall. All from distant memory, so don't pile on if I got wrong. All this to compensate for the greater thickness of the adjustable spring plates, compared with the originals.
You also want longer bolts and the thicker spacer for the lower, rear mounting bolt.
Registered Minimalist
^ This. If it's the car from your "garage" link it's a 73. Did you put the spacer back in the rear bottom corner? The cover should be perpendicular to the ground like a T. If there's a weird angle to it, you may have left out the early car spacer.
It's just a single spacer. It's not one on every corner. You do use additional spacers if you use polybronze bushings, but not the rubber bushes. ![]()
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads Last edited by 75 911s; 11-04-2021 at 12:27 PM.. |
Thanks but the spacers are correctly installed
Thread Tools | |
Rate This Thread | |
