SC intakes 80 - 83 same?
Are all the intakes from 1980 to 1983 the same? Can I swap a 81 or 82 intake onto an 83 engine or an 80 and everything will be fine? Do they all use the same moronic, WUR, Fuel distribution? Thanks all.
The intake runners are the same, and the same as 74 to 77
The 81 to 83 fuel dist are the same, the 80 FD still had plastic fuel lines and more info wires on the lambda harness for 81/83 Bruce |
ROW '78 911 Targa
Plus, differences between 930/16 (US with Lambda) and 930/10 ROW engines.
Not interchangeable.
Crotchety Old Bastard
Systems don't mix and match well but you can transfer entire systems from one engine to the other. If doing that I would go with the larger port 78/9 CIS system.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
This engine will be going into a 914 with no need for emissions so if I can go with a more simple system then I will. Does it matter whether it is a Euro or US 78/9 CIS? They look to be the same, at least FD. |
ROW '78 911 Targa
If using 78/79 large port runners, you’ll want the large port heads.
Same as the ROW from 78-83 for runner size , port size and no Lambda.
Senior Member
'83 intake runners are narrower than '78. I do not know when they made the change.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
'78/9 CIS is same US and Euro. No Lambda and larger ID runners.
Reiver
as he said the 930-10 '83 SC Euro/ROW had the large runners and no lambda....fuel enrichment AFR on the Euro's controlled by the WUR.
De Oppresso Liber Strength and Honor 5th Legion |
