flat6pilot's Avatar
Turn Signals Not Working
I've been searching through all the turn signal threads and I've yet to find one that matches my symptoms.
1980 SC
Neither side of the turn signal works.
No recent work has been done or bulb changes. The only recent 'issue' I had was the speedometer stopped working. I pulled the gauge to look at wires. Pulled and reseated everything and pulled the sensor on the transmission. It started working again. Otherwise, nothing else has been done to the car electrically. Turn signals just stopped working a few weeks ago around the same time (but after) the speedometer stopped.
Here's the facts:
-Because of the turn signal issue, I replaced turn signal switch. (I have high beams again for the first time in 14 years!) Still no turn signals. (I have the headlight relay kit coming as well.)
-At no time during any of the variations below does either turn signal indicator on tach light up. I checked the left bulb and it appears good. (the blue high beam light comes on when I flash the high beams, but it seems dim to me.)
-Hazards (4-way flashers) work normally.
-All fuses are good.
-With key off, turn signal lamps light steadily (no flash) along with the brake light on that side and front corresponding headlight parking lamp (Not the main headlight) i.e. left turn signal cause both front left and rear left turn signal indicators light up at normal brightness along with the brake light and headlight on that side. I think I recall it would do this anyway when the turn signals did work.
-With key on (fuel pump on), turn signals do not work at all. No steady lights or anything.
-I pulled the flasher relay to inspect and clean.
-I have a new flasher relay on order but I don't have high hopes.
Not sure what else I can check or test. I have the electrical schematic but everything seems ok but the tach indicator lights not coming on even with the 4-way flashers.
I'm usually pretty good with electrical stuff but this has me a bit puzzled.
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs
Old 11-09-2021, 08:08 PM
midnight911's Avatar
I'd replace the relay and see... Relay fixed the problem I had which seems somewhat similar to your case...
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 11-10-2021, 06:25 PM
Check the pin connectors where they plug in under the dash. Check the connections at the light switch and hazard switch, something could have pulled loose when you were replacing the turn signal switch.
You can test the flasher with a test light to see if it’s sending the right signals out.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 11-10-2021, 07:25 PM
Send a message via AIM to fintstone
Do your back up lights work?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 11-10-2021, 07:40 PM
flat6pilot's Avatar
No but they didn’t work before when the turn signals were working. Shared fuse is good.
Thanks for the replies so far. I’ll continue testing connections for continuity while I’m waiting for the flasher relay to show up tomorrow.
Old 11-11-2021, 07:29 PM
Have you checked the wire for a loose connection at the fuse (11)...or voltage at the flasher (not really a relay)?
Old 11-12-2021, 12:23 PM
Heck, I’m only 5 not 71!
targa80's Avatar
The below post provides the schematic which is valid for your 80SC. Since your four way flashers work then you do not have an issue with the flasher relay. When the four way flasher is active fuse 17 provides power to the flasher relay through the hazard switch at pin 30 to pin 49. I believe your problem is related to no power applied to the flasher relay when the four way flasher switch is off and power to the flasher relay is provided by fuse 11 via pin 15 to pin 49 on the hazard switch. You have replaced the turn signal switch so that is not your problem. Check fuse 11 and power on pin 15 on hazard switch to pin 49 on the flasher relay.
Flasher/Hazard Mods on my 80SC
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 11-12-2021, 04:18 PM
When I had this problem on my 1978 SC it turned out to be a slightly corroded fuse 11; brake lights also didn't work because of this fuse.
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 11-13-2021, 04:58 AM
flat6pilot's Avatar
Thanks, I'll check this lead out. I did replace the flasher relay with new and no change as expected.
Old 11-14-2021, 01:44 PM
flat6pilot's Avatar
Found the issue. Bad wire from Fuse 11 to terminal 15 (GRN/RED wire) on the 4-Way Hazard switch.
Thanks for the input everyone!
Old 11-14-2021, 09:31 PM
l_turn9's Avatar
Had the same problem on my 74 911. Turned out to be the Emergency Flasher Button. Seems like the wire between the t'signals and 4 way flasher was poorly shown on the Flow Diagrams (all I had). But I replaced the 4 way Switch and all was well again.
good luck -
Old 11-19-2021, 07:41 AM
flat6pilot's Avatar
good luck -
I wasn't going to say anything, but since you mention it. I was going to track the bad wire I found from fuse 11 back to the 4-way flasher to replace it and discovered the green/red wire that comes from the flasher does NOT go to Fuse 11 like it says on the schematic. It actually went to fuse 17. Which turns out DID have a broken fuse. I couldn't see it because it fell apart in my hand after I removed it.
Replacing the fuse fixed the issue.
Not sure why it was on that fuse and not on 11 like it was shown... previous owner or shop moved it for some reason?!? I don't know.
Old 11-19-2021, 08:43 AM
