Location: behind the redwood curtain, (humboldt county) california
Testing oil tank level sender for re-use - advice???
Evening Gents and Ladies, (your choice :-)
I have received back, my 74 oil tank after cleaning testing and painting by Pacific Oil Cooler, (had cooler done too - OK) Can anyone help me test the sender for re-use? What ohm reading should i expect at full droop and max?? Any other things to check?? Is the cork, or rubber gasket the best way to go?? Any gasket sealer recommended for reassembly?? Any other helpfull hints?? Dad's car is getting close to getting back on the road after 10 years on the slope. This might be a good time to offer my heartfelt thanks to the many members of this forum for their advice and help. Thanks, chris |
From what I know, the rubber gasket is for the gas tank. The oil tank uses the cork gasket.
NO gasket sealer. It is just a few inch pounds of torque on the bolts to tighten the sender to the tank. I put mine on, and several months later went in and gave them a little double check in case the cork had flattened a bit in the squeeze.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Thanks, Glenn,
I'll give that a shot when i get back into the shop. Will also post ohm readings for full and empty - hopeing for confirmation of values before installing tank and sender back in car. Most of your 2020 pic posts in "off topic" are incredible photos, thanks chris |
once you take the oil level sending unit out and check it has no broken coil wires , you can adjust the plates where the arm leans against to synchronized it with your interior level gauge so it reads the same as the dipstick- each end is either top
and bottom on your oil level gauge... ![]()
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 01-13-2022 at 05:16 AM.. |
Thanks Pro,
Your pics help understand the mechanical adjustment to the electrical issue. As soon as i get a chance to get some garage time i'll set it up and check it out. Appreciate the help. chris |
