Roy M's Avatar
Not getting full throttle?
There have been threads lately regarding not getting full throttle - (I've subscribed to them myself) and various discussions have gone on regarding adjustment of linkages etc.
Last week I worked on my linkage (this is a RHD car so things may be different) to cure a sticky throttle. The pivot point on the side of the gearbox was corroded and sticking. A clean up and grease made it ok again. After doing this I thought I'd have another go at getting full throttle - no need - the extra half inch had mysteriously appeared!
As I said this applies to a G50 3.2 Carrera but the principle should be the same!
Roy
Old 05-19-2003, 12:44 AM
AirCooledExcellence's Avatar
Congrats on your WOT! You might be able to keep up with the SC's now
Cheers
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD
1987 930 - SOLD
1983 911 SC Targa - SOLD
http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else
Old 05-19-2003, 12:46 AM
cary's Avatar
I think your talking about the bell crank. ( I believe it's called ) You don't want to use grease down there. It can pick up debri and cause your throttle to stick. Perhaps, wide open. Not good.
You should clean it up. Make sure the tolerances are right. Then lube it with graphite. The nylon/plastic bushing are cheap to replace if they're worn.
Good Luck
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 05-19-2003, 04:48 AM
Roy M's Avatar
Cary
It is teh bell crank I'm talking about - I've basically filled the void between the bushes and the shaft with grease to stop water entering which I assume is the source of the corrosion on the shaft. From the outside of the shaft there's no real grease showing so I'm fairly confident that I'll be ok (although I'm taking the shaft out at the next gearbox oil change to do a more permanent fix)
What I don't know is whether the nylon bushes will be affected by the grease and break down?
Roy
Old 05-19-2003, 06:43 AM
911 + 129 = JOB
PDACPA's Avatar
Can someone post a picture of what they are talking about? I have read threads and looked at mine and I am almost certain that when I press the gas pedal down that I am not getting full throttle.
Picture is a 1,000 words.
1989 911 Carrera Coupe 3.2
2012 BMW 135i M Sport
"It is not how much power you have, it is how much you have left to spare!"
Old 07-02-2003, 08:09 AM
Could be worse, you could have the six hundred rods associated with a glorious MFI car
Dennis H. 72 911E 2.7 RS stuff
72 911T with a 2.7(Sold 5-13-2011)
2012 Kona Blue Metallic Mustang GT Convertible 6spd
67 Mustang coupe future SVRA group 6 car
63 Falcon hardtop 302/4spd
Old 07-02-2003, 08:14 AM
911 + 129 = JOB
PDACPA's Avatar
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
It's a midpoint pivot in the throttle linkage that rides on a shaft that protrudes on the driver's side half of the gearbox. It's the only pivot next to the gearobox that's related to the throttle, not hard to spot.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 07-02-2003, 09:32 AM
alf alf is offline
alf's Avatar
I am with PDAPCA, could someone post a picture?
I have to itch to tinker over the long weekend.
alf
88 Carrera Coupe
Pelican Since 2002
All Zing, No Bling. ok, maybe a little bling.
The Roach
Old 07-02-2003, 09:46 AM
Bones's Avatar
Originally posted by Roy M
Cary
The bushes shouldn't deteriorate because of the presence of grease . Also any grease packed around the pivot may atract dirt but it will be keeping water out and will form a mobile sheath around it .
Old 07-02-2003, 10:50 AM
Roy M's Avatar
Hope these help - first one is linkage under car on side of gearbox (this is RHD car) second one is throttle as was before cleaning / lubricating
Hope this helps
Roy
Old 07-03-2003, 06:46 AM
911 + 129 = JOB
PDACPA's Avatar
Roy - Where do we make the adjustment to make sure that the throttle is openning completely in the first picture.
The second picture is where I have looked for means to adjust, but it basically raced the engine and did not seem to appear to be pulling the cable completely taught when the gas pedal was fully depressed.
Thanks for the pictures and info. I feel really dense about this one.
Old 07-03-2003, 08:02 AM
VenezianBlau 87's Avatar
The part number for the bushing (2) is: 914 423 211 00
I removed my engine/trans (first time) last weekend. Both of these plastic bushings fell out in pieces as I slid assembly off of shaft. Two new ones on their way from Pelican.
Cheers,
Bob Sauerteig
Bob S.
'87 911 ("Hardtop" per neighbor)
Old 07-03-2003, 08:11 AM
Roy M's Avatar
I made adjustments at the end where you can see the rubber bellows (goes to the pedal). Rubber bellow to bell crank is a threaded rod and ball joint - remove the clip and then the ball joint and turn whilst holding rod - you'll get some more throttle.
However, the greatest effect I got was by removing the circlip on the bell crank (after removing connections) removing it as far as I could (it caught on the suspension arm so I couldn't remove it fully), greasing and replacing - all the 'lost' motion came back and no sticking throttle!
Roy
Roy
Old 07-04-2003, 12:16 AM
