911 stopped running, won’t restart
‘89 911: Does crank but won’t fire. Let sit a day but then restarted and stopped again.
Hopefully something simple like a DME relay. Might try swapping that out for a start.
Walt 82SC 3.0 81SC 3.6 |
Well, not much information to go on but my first thought is a spark issue, a CDI that's failing.
I would start with checking the usual culprits...spark, fuel issues and go from there. Walts suggestion is a good one...DME relay is an easy place to start
Lou |
It could be the points on a old 911, or the crank sensors on a 3.2.
Mark, we need to know the year and of your 911 as a minimum to start to make guesses.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Its easier to help when you say what youve tried and checked. Is there fuel in the tank?. Can you hear the pump etc etc etc
Grappler
An engine basically needs fuel, spark, and compression to start.
We know it has compression, so next time it no starts, check for fuel and spark.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
As I say starts but will then shut down and not restart but does if I let it sit awhile. I thought crank sensor and responses saying DME relay are helpful places to check |
Senior Member
To check for spark, my favorite method is to connect a timing light. If the timing light flashes, you have spark.
If you have spark but no fire, then apparently you don't have fuel.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
