Instagram: @TuitTech
Old 03-29-2022, 10:07 PM
Old 03-29-2022, 10:11 PM
My first attempt at bolting it in the car,
Old 03-29-2022, 10:20 PM
993TT engine?
Old 03-30-2022, 08:18 AM
Eva
911SauCy's Avatar
and One fo duh hoessss !!!
Cripes, took a guy long enough to build this one-off, mind-blowing, example of backyard hackery
Only a legend tears down a 993TT motor and tosses the parts in a Grapes Box...
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 03-30-2022, 08:23 AM
Originally Posted by Mocker View Post
993TT engine?
Correct sir
Old 03-30-2022, 08:28 AM
Hard Facts
Old 03-30-2022, 08:43 AM
Manda Racing's Avatar
My brother traveled all over Europe back in the late eighties(?). He sent me pictures of the outside of the P factory after hours and one of these Ruf was the only car parked out front.
Is that a factory engine carrier for a TT?
Beautiful subtle build.
Old 03-30-2022, 11:16 AM
Yes it’s a stock carrier, I had to modify the bar slightly, it was cut and welded, then powder coated. I had to maintain the stock carrier cause it houses the turbo return system
Old 03-30-2022, 12:41 PM
Off to my homies shop to fab up a exhaust and intake set up. The plan was to duplicate the stock intake system without all the smog and sensors. Also, my main thing with the exhaust was the maintain the oval exhaust tips that the RUF cars have
Old 03-30-2022, 12:50 PM
Old 03-30-2022, 12:56 PM
I spy a b5s4 smiling lower grille in the homie's shop. Also an excellent 6cyl. tt car if I dare say. In particular: avants rule the fast Audi kingdom
oh, back on subject that exhaust is pretty nice too
Old 03-30-2022, 01:27 PM
So, I knew for myself the oil system was going to be a big hurdle. I started by sourcing a entire NOS 72 set up
Well, pucker up buttercup! Lucky to have a local guy with a 72 so I was able to take a template of the set up
Old 03-30-2022, 01:41 PM
My plan was to fab up a plate I could bolt into the stock oil tank hole that would mount the 72 thermostat
Old 03-30-2022, 01:53 PM
Then I had to make some jumpers from the stock carrera cooler to the front mount cooler, at the time I thought I needed two coolers, but fast forward a few months, it’s total overkill. Car is actually running to cold currently
One of the other RUF mods was the lack of jack holes in rocker panels, so stripped mine down, welded shut, new wurth and paint and bam!
Old 03-30-2022, 02:03 PM
Old 03-30-2022, 02:06 PM
Old 03-30-2022, 02:11 PM
Wow
Old 03-30-2022, 03:20 PM
Next order of business was to sort the deck lid and wing situation.
Old 03-30-2022, 05:58 PM
Next the wing. I’ve seen a lot of people bolt a carrera rubber lip on a 930 wing, while it can be done, nothing lines up properly and in the end just looks horrible. So, I cut up a turbo wing and re fiberglass all the lines and curves to match the Carrera rubber!
In the last pic you can see I separated the wing in two pieces so I could glass and body work the inside so this will never be visible
Old 03-30-2022, 06:27 PM
