Name of switch
Can someone tell me the name of the blue switch in the area of the air flow plate on the back side of engine. I can't seem to find any reference to it in the Bentley
Thx
Old 03-31-2022, 06:05 AM
MBAtarga's Avatar
Which make/model of car? I assume Porsche?
Mark
'83 SC Targa - since 5/5/2001
Old 03-31-2022, 06:29 AM
Air Flow Sensor Plate Switch........
Thx
Hugh,
That is the AFS switch that supplies ground contacts for the terminal #85 @ FP relay socket and @ alternator D-. To get a better understanding how this switch works, use a continuity tester @ terminal #85 (FP relay) and a good ground contact. Raise the sensor plate and you will have an open line.
Tony
Old 03-31-2022, 06:45 AM
Sorry MBAtarga, I should have been a little more precise with that question.
Old 03-31-2022, 07:41 AM
Smile
Originally Posted by boyt911sc View Post
Hugh,
Tony
Thank you Tony, I'm in the process of putting things back together on the engine and was unsure of the placement of the various black connectors in that area so by knowing the ID I can refer to the wiring diagram and confirm the color codes on each connector.
If there is a "next time" I'll be sure to identify each connector as I remove it.
Old 03-31-2022, 07:48 AM
Wire color...........
Hugh,
Just make sure that the plug that goes to the AFS connector has 2 brown wires. The standard color for the plug is aqua blue. This particular plug for the AFS is the only plug in the engine harness that has 2 brown wires (no power source). Due to its proximity to CSV and AAR plugs people inadvertently mixed them up.
Tony
Old 03-31-2022, 08:23 AM
Hugh,
Tony
Thank you Tony, I got it all sorted.
I have one more question. There is a long wire with a female spade connector that is either bluish or greenish that I don't remember where it plugs into.
Can you help?
Thx
Old 03-31-2022, 12:55 PM
Can you help?
Thx
Hugh,
Could you post a picture of the wire in question? Thanks.
Tony
Old 03-31-2022, 01:40 PM
Hugh,
Tony
I haven't mastered posting pics on the forum but I did send you a photo via email.
thx
Old 03-31-2022, 03:48 PM
thx
I think I found out where it belongs. It's a blu/wht wire and goes to the front of engine to the oil temp. switch.
Thx
Old 04-01-2022, 09:53 AM
