Discseven's Avatar
FEBI - anyone running their timing chains?
Am considering getting into FEBI timing chains. Thought to solicit input on them before pulling the trigger. This brand is part of the Bilstein Group. While that says something, I'd prefer knowing others are running these chains without issue---or with issue if that's the case.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 08-01-2022, 11:15 AM
RDM RDM is online now
Coram Deo
RDM's Avatar
I'm gonna take that as a no :-)
I've used a number of Febi parts on my old Mercedes and been satisfied.
That said, what could go wrong should a timing chain fail?
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 08-02-2022, 10:55 AM
Discseven's Avatar
"No" it is! Appreciate the comment re your Benz RDM.
Chain fail... fine word for that happening is 'catstrophic.' 'Expensive' also comes to mind. Basically sycronization between the valves and pistons comes to an end. So lots of things crashing about. That's not to mention what the loose chain will do.
Karl ~~~
Old 08-02-2022, 05:35 PM
Coram Deo
RDM's Avatar
Karl,
You've always been a risk taker and an experimenter- before I opened this post I was sure you were going to go for it!
Dru
Old 08-04-2022, 11:26 AM
Jeff Alton's Avatar
Febi, a known good brand and OE supplier. Why are you asking? Only part available or 5 bucks cheaper?
Cheers
www.turn3autosport.com
Old 08-04-2022, 10:13 PM
Discseven's Avatar
Karl,
You know me well RDM. I do plan to dive in... but would put the brakes on were there any screamingly bad news.
Cheers
Jeff... I ask having never come across the Febi brand before. Reason to consider this alternative to Iwis is indeed price. Iwis chain can be had anywhere from $57 to $100. Why pay $100? Febi chain... $30. Is paying more worth it? Personal call I believe. In any case, few dollars on one part one way or another is inconsequential. I'm into a rebuild here. You know thousands are heading out the door to support this cause. Makes sense to me to give as much business as possible to businesses that make a point of being price competitive.
My favorite price point comparison... our idle control valve. One can buy these anywhere from $1,100 to $47. (There's not much inside these.)
Karl ~~~
Old 08-05-2022, 03:22 PM
Jeff Alton's Avatar
You will be fine with a Febi chain. Good/Great products. Iwis is likely the gold standard, but nothing wrong with a Febi what so ever.
And yes, I hear you on the ISV question....
I totally get your question, just asking for clarity.
Cheers
Old 08-05-2022, 08:14 PM
Discseven's Avatar
Cheers
Read your website Jeff. Powerful statements throughout. In a world of marketing BS, it's a challenge to know who to respect, or otherwise. Would be great if you were a short, few tight turns nearby. I'd be there... to get to know you---to confirm the man being more than the words. I shall trust you are.
Damm fine message/website. Most of all: fine story about you & Dad.
PS - Febi chains ordered. Input appreciated
Karl ~~~
Old 08-06-2022, 09:38 AM
I put some new Febi chains in a 2.7 build around 10 years ago, lots of revs later still good
Old 08-07-2022, 06:44 AM
Discseven's Avatar
Appreciate + comment Eastbay.
Karl ~~~
Old 08-07-2022, 07:57 AM
Jeff Alton's Avatar
Karl,
Thank you for the kind words.
Cheers
Old 08-10-2022, 06:44 PM
