LinkBack | Thread Tools | Rate Thread |
How does the fuel gauge low gas warning light work, even when level is incorrect?
Gas gauge was stuck at half.
Yet, warning light illuminated. Realized sender or gauge was stuck or faulty. I removed sender and made sure it wasn't stuck. It was not. I cleaned 3 prongs on top of the sender unit with wire brush. Gauge now correctly shows empty. How does gauge show incorrect level, yet low gas warning light works?
1986 Bosch Icon Wipers coupe. |
Been here a while
the light is triggered by a contact on the sender, when the float is truly at the bottom the light turns on, the gauge is a resistive reading based on how high or low the float is, so some crud on the wire will make the gauge inaccurate, but most times, the light will always work
looking for 1972 911t motor XR584, S/N 6121622 |
don't trust the gauge, trust the light.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Administrator
On this older thread someone had a similar issue. It goes into pretty good detail on troubleshooting the sender and the rest of the system too.
https://forums.pelicanparts.com/porsche-911-technical-forum/847863-fuel-sender-fine-open-fuel-gauge-itself.html -Matt |
How much fuel remains in the tank when the light comes on? Mines come on a couple times on hills when I was low but generally fill before it gets there.
1988 Carrera
In my 88' I let the tank go down until the light came on. I wanted to change some lines. Drained the tank. Took out over four gallons. YMMV. Any way I figured that I had about 80 miles left until bingo.
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
Good info, thanks.
So, the light verifies sender is not stuck, but contacts need cleaning, since gauge is not accurate
Exact same symptoms here, the light is accurate, and yet the needle never goes below about 1/3 - so i just trust the light
1988 911 Carrera, M491 Cabriolet 2016 Cayenne |
On my '82 I drained the tank & serviced the screen/filter. After re-assembly, I added fuel incrementally until the light went out. Took about 2.5 gallons to extinguish the light. In my estimation, when the light comes on you've got about 40 miles, max., maybe less. YMMV.
The needle should get closer to E. Quote:
It has been a long time since I read my owner's manual, but I think it mentioned a 2 gallon "reserve" when the light comes on. In the daytime, with sunglasses on seeing that light is almost impossible. At night no problem.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
light
Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 07-28-2022 at 01:57 PM.. |
