reconditioning wiper switch
The wiper switch for my 1977 3.0 Carrera Targa is malfunctioning. New ones cost over $AUD500 so I'd like to recondition it. Does anyone know how to do this? If so please reply so I can give it a go.
Old 08-24-2022, 08:17 PM
ROW '78 911 Targa
timmy2's Avatar
turn signal switch quick fix pictures
Oops, wiper not turn…
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-24-2022, 09:17 PM
What’s the symptom? I think different problems have different solutions
Mine doesn’t turn off once they are running, unless you cut the ignition. Haven’t figured out what that is.
Old 08-25-2022, 05:43 AM
MichaelSJackson's Avatar
Do the wipers just stop and don't return to the parked position? If so, try pulling on the switch arm, along the line of the steering column. (Towards you.) Do they then park correctly? If so, the fix is fairly easy.
Undo the plastic clam shell hiding everything. You should then be able to see the "reed" switches the arm should actuate. Now that you can see the reeds, watch what happens when you tug on the arm and they park correctly. That is the contact that should be happening when you return the arm to the off position. (Easier/clearer for you to watch and understand, than for me to describe it and confuse you.)
Once you see how they should work, just use a small needle nose to gently tweak the reed(s) to get them to make contact, like they used to.
Hope this matched your symptoms.
Old 08-25-2022, 01:05 PM
On my list of To Do's.
I also think this "fault" is the root cause of most problems with the intermittent wiper feature.
1978 SC Targa
Old 08-25-2022, 01:42 PM
917_Langheck's Avatar
Do this only AFTER disconnecting the battery... of course, then make an adjustment and reconnect; disconnect, adjust, reconnect as necessary. (BTW, I found a flat blade screwdriver for adjusting the switch "reeds" works well, and a little emory paper to clean the contacts helps).
____________________________
If it's not leaking, it's out of oel...
Old 08-25-2022, 02:15 PM
