reesestewww's Avatar
Question Pyrometers
Im looking at purchasing a pyrometer for tire temps and other items. Can you use one of the laser (or IR) pyrometers on tires? Or do you need the unit with the probe? If so, can you use the pyrometet with the probe on ther things than tire?
http://www.discoveryparts.com/cgi-bin/store/commerce.cgi?product=pyrometers
R
Past:
04 Anniversary 911 #0895, 82 911 SC, 88 Signature Series Carrera, 88 911 Turbo Cab, 73 911T, 63 356B, 06 Cayenne
Old 05-29-2003, 08:37 AM
Irrationally exuberant
ChrisBennet's Avatar
The IR ones are not suitable for taking tire temps as the tires surface cools too rapidly. The "laser" ones are IR ones with a laser to help you aim/see where you are taking your measurement.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-29-2003, 10:14 AM
Automotive Monomaniac
Emission's Avatar
I have been using an Infrared Laser Thermometer for about a year now. It works very well on tires, exhaust manifolds, calipers (I diagnosed a stuck caliper when the temp was about 10 F. hotter than the others) and many other things around the house.
Even though the tire surface cools quickly, you can still check the temps across the tread with an infrared thermometer (and on the sidewalls) to get a very clear reading of what is going on. You can also use it to check caliper temps to check your brake system (something you cannot do with a pyrometer with a probe), exhaust temps, A/C temps...
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 05-29-2003, 10:46 AM
Bill Verburg's Avatar
I agree w/ CB on this one, too much cooling occurs too quickly and non uniformly.
Bill Verburg
Old 05-29-2003, 01:07 PM
A few years ago there was an article in Grass Roots titled "The Big Stick" (I think) by a track tire vender/consultant. He basically said that the tire temp data method of tuning was developed on open wheel, nylon belted or bias ply tires (can't remember which) and was less applicable to steel belted DOT radials running on closed fendered cars.
The reason being that the steel belts hold and conduct heat across the tire and the outside edge of the tire was more exposed to the cooling wind than the inside.
Don't shoot the messenger, just thought it was interesting.
-Chris
Old 05-29-2003, 01:24 PM
jphillips-998's Avatar
Laser will not do any good on the tires, you have to get into the tread. Lasers will give you either too hot if right off the track. Kind of like touching the outside of a steak off the grill. The outside does cool too fast from a cool down lap.
Jeff
'04 Cayenne S Hauler
'98 993 Cab
'74 Euro Carrera - SOLD
'91 944S2 Track Car
Old 05-29-2003, 01:52 PM
Emission's Avatar
First of all, I never said my IR thermometer was as good as a pyrometer with a needle, it is just much better than the back of your hand on the tire. Used correctly, it is very accurate, and it will tell you a lot about what is going on (but not as good as anything that probes into the tire).
For me, I choose chalk, a good tire gauge, and my IR thermometer. At my level (non-racing), this is plenty.
Old 05-29-2003, 02:26 PM
Laser is for pointing only. It has no effect on the measurement. It's the IR senor which picks up the reading. I know because my company makes these IR meters.
Caliber
1987 911 Cabriolet
Old 05-29-2003, 04:25 PM
Stay away from my Member
campbellcj's Avatar
If you're gonna get a probe (tire) pyrometer, I might suggest springing for one with memory capability. I didn't, but soon learned that taking and writing-down 12 readings by yourself -- in the blazing sun and 30mph wind -- is a PITA.
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 05-29-2003, 07:06 PM
