fogcity's Avatar
Smile a real quicky, PLEASE
Going to be parking the 911 in airport long term parking for a few days. To discourage theft (although only a bit, I know) do I have to remove both battery terminals or can I just remove the negative one?
Thanks,
Ps - should you see a platinum Carrera in the parking lot, give it a smile and make sure no one is messing with it
1984 Carrera Coupe
Old 05-30-2003, 11:03 PM
fogcity's Avatar
anybody up?
1984 Carrera Coupe
Old 05-30-2003, 11:29 PM
TYPE 901/05's Avatar
put a wire in your pocket
pull the distributors coil wire, take it with you, and have a good trip.
Just don't forget to plug it back in when you get back.
Shawn.
with s cams and carbs
Old 05-30-2003, 11:41 PM
Automotive Monomaniac
Emission's Avatar
You can just pull one (negative wire). This will also prevent the battery from trickle discharge.
But, if you take the coil wire, they won't be able to simply re-attach the battery...(and, most likely, they won't have a spare).
Personally, I'd do both if you are worried.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 05-30-2003, 11:47 PM
if one is good...than two is better...
Emission has Established your (E) mission. Please do not put the coil wire in your pocket as I mentioned before.
Airport security and all.
Two pelican heads are better than one.
Shawn.
Old 05-31-2003, 12:11 AM
fogcity's Avatar
Cool, thanks. Hey, where do I find my coil wire?
I hope you smarties are still up
1984 Carrera Coupe
Old 05-31-2003, 12:23 AM
fogcity's Avatar
Shawn, Emission: you guys still there?
1984 Carrera Coupe
Old 05-31-2003, 12:37 AM
DJB DJB is offline
DJB's Avatar
It goes from the centre of your distributor to the coil.
Cayenne Turbo - Cargraphic Stage 2 Power kit, lowering module
997 C4 Cabriolet - Basalt Black
86 Turbo Body 911 Cab - Many Mods
Gone and Missed:
97 993TT: PSS9, CarGraphic Exhaust
Old 05-31-2003, 12:41 AM
Oh noooo...
I am an early car guy. Mine has six going to to the engine's spark plugs and one going up and to the left...to a blue thing about the size of a 10oz can of juice...it's blue and has BOSCH written on it. Your in a....what SC...should be similar, the coil could be on the fan shroud though. Look for the one distributor wire that begins at the center and runs away from the rest of the spark plug wires. Later car guys...Help!!
Shawn.
Old 05-31-2003, 12:43 AM
fogcity's Avatar
I think I can figure it out from here. Thanks, guys.
1984 Carrera Coupe
Old 05-31-2003, 12:44 AM
Emission's Avatar
It has the yellow arrow aimed at it.
Have a safe trip!
Old 05-31-2003, 12:52 AM
Sonic dB's Avatar
Or you could remove the DME relay from under the drivers seat....
Old 05-31-2003, 01:07 AM
or...
1.) leave it at home.
2.) let your friend/family member drive it back home(and have loads of fun while your gone)
3.) flatten the tires and punch a hole in the fuel cell!
Shawn.
Old 05-31-2003, 01:19 AM
andyu911's Avatar
How about the fuel pump relay?
Andy
-'87 Carrera -'73 914 2.0
-'06 Frontier -'02 VW Golf TDI
-'07 GT3 RS -'07 Top Kart KPV-4
Old 05-31-2003, 01:26 AM
what do you guys do down there...
drive your p cars year round? Wow...I want to move there. Could I make a living down there if I bring my snow plow trucks and set up?
I wanna go to a restaurant and hang with super models, rock legends, and movie stars.
I guess I am an out cast. Park it at home doesn't work on this board. I will go back to my local northern lights watch and seal hunt board.
Shawn.
Old 05-31-2003, 02:57 AM
kellzey's Avatar
Cool... Platinum colored 911 Carrera at the San Francisco airport left unattended.
Checklist...
1. Check battery connections
2. Bring distributor wire
3. Check DME relay (bring spare just in case)
Cool! Free 911. Woohooo! We're on our way.
Just kidding! Have a safe trip.
Regards,
Qarl
Old 05-31-2003, 07:09 AM
Huey58's Avatar
Just take a cab to the airport then you don't have to worry about it while your gone!!!!!!
Huey
86' 911 Cab
Old 05-31-2003, 08:38 AM
pwd72s's Avatar
I'll vote for the take a cab or have a friend deliver you option..
Old 05-31-2003, 08:49 AM
Re: a real quicky, PLEASE
why don't you ask around for info on how many cars are boosted from the airport every hour ..............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-31-2003, 09:30 AM
Phoenix's Avatar
Use an old trick my Dad used to do to keep customers from taking their cars home without paying using a second set of keys.
Pop off the distributer cap, remove the rotor, replace the cap.
(He used to do the same to me to keep me from borrowing our old beetle. I got wise and bought a spare rotor :-) )
...Oliver
'73 911T: 2.9ltr w/ PMO EFI
Old 05-31-2003, 09:45 AM
