| Registered |
			Triangle of death done | ||
| Targa_PB_78_SC |
You might want to coat the oil light sender in JB weld
				__________________ BareRearedRookie | ||
| Registered |
			What type of JB weld, around the brown area?
| Targa_PB_78_SC |
Right, circle to cover around the plastic area which can crack and leak. I use the black-and-white-two-tube stuff, (the original) good to 500 degrees I think their strongest. You might need another washer if you remove your sender to coat it good.
| Registered Join Date: Jan 2001 Location: Carlsbad,Ca.
			I wrapped blue tape around the hex portion and then filled it in with JB Weld. Peeled the tape off later and it looked really nice after:<)
				__________________ 1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS | ||
| Registered Join Date: Sep 2001 Location: Columbus, OH
			Where does the other end of the vacuum hose, that goes down into the rear crossmember (in the pictures above) go?  I removed a bunch of stuff, including CIS, and that hose was disconnected.  I pulled it out of the hole in the crossmember to find it just dead-ends, and is attached to nothing. Thanks in advance.
				__________________ Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo | ||
| Registered | Quote:
  https://bit.ly/3FVeQlm Thomas
				__________________ 1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. | ||
| Registered |
			Here's my CIS ready to go in. I left runners 1 and 4 for easier access to some bolts. | ||
			This one.  Mine was also cable tied. When i removed the tie and pulled it just came out of the crossmember. I assumed it was an old hack, until i saw it here.
| Registered |
			I can have a look on under my car to see if I can see were it terminates
			If yours is like mine, it terminates about 4" into that crossmember, to nothing.  Question is, where does the other end of the hose go.  Cruise control?
| Registered |
			Can I change the upper valve gasket without draining the oil? Maybe easier without the CIS | ||
| Registered |
If memory serves, that’s exactly what it is, the atmosphere air end to the cruise control.
				__________________ Rutager West 1977 911S Targa Chocolate Brown | ||
| Registered |
Yes, all of the oil drains to the bottom of the engine, and you might even want to adjust the intake valves while you're at it.
				__________________ 1983 911SC 1977 930 Turbo (again) 2018 GTS 2023 Audi A4 '74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) | ||
| Registered |
			Another “while you have it out”. My engine is back in the car after being on the engine stand all of 2021. Last weekend I decided I needed to finally verify my CSV was in fact spraying fuel out of it. In the year the motor was on the stand I removed it to put in new O rings but never tested for spray function. Anyway doing it with the CIS back in the car is not fun. Took me an hour and a half to remove it and probably 4 hours to reinstall using lights and mirrors. With the CIS on the bench it would take only a few minutes. I would never do it in situ again. Also check to see that you have the correct mounting flange. There are threads with pictures that show the difference between flanges. | ||
| PCA Member since 1988 |
			I think I mentioned this awhile back, but I'll say it again since you're almost done.  Consider removing the idle air valve and decel valve and associated plumbing.  Without that stuff in the way, you can reach the parts in the TOD much more easily.  When I reinstalled my rebuilt engine a year ago, I forgot to fully tighten the oil pressure switch.  Of course, I had a seep of oil down the top of the engine, etc.  I was able to easily put a mirror back there, see that it was coming from the switch, and then remove it, check it, reinstall it, and tighten it, WITHOUT futzing with the CIS.  Now, my 1973.5 car has a hand throttle, so I can just set that for a few minutes to let the engine warm up.  Otherwise, you have to keep your foot on the gas to hold the RPM up for a minute or two, or start driving it immediately.  IMO, it's worth the tradeoff.
| Registered |
			Everything is back in now, had a fuel leak from the cold start valve but all tighten up now and no leaks.
| Registered |
			So I tried to start the car, I haven't received the fuel pressure tester I ordered yet and was a bit inpatient. I also put in new plugs wires cap and rotor. I think I installed the plug wires in the right position on the cap. When I start the car the car rpm surges and back fires and shuts down. I know I should check the fuel pressure before but could my wires be in the wrong position? Is there any adjustments to the throttle position micro switch which needs to be adjusted? | ||
| Targa_PB_78_SC | Quote:
 Sometimes sputter and BF can occur until the lines get all primed. | ||
| Targa_PB_78_SC |
			After wires verified, I’ve primed by (air cleaner off) lift the CIS plunger slightly with key on, as soon as you hear fuel squirting in the injectors let go of plate plunger. Wetting down the cylinders with gas not great. If your car has sat a long time you might crank a while to get oil pressure. You should pull the CDS plug to do this. Although I’ve done it with the fuel pump relay out. Last edited by mike sampsel; 01-07-2023 at 05:45 AM.. | ||
