Central Locking Control Module - Board Help.
Trying to tackle central locking issue (not working). This is part 91161811301 out of an 89 911 3.2. If anyone has a pic or a unit about, could you please post a picture of the board. A friend noticed an apparent solder break. Not sure what this is, but it doesn't look right. This may be a Hail Mary, but worth a try. Thanks.
Board with potential issue.
Close up
Old 01-12-2016, 06:41 PM
964TargaC2's Avatar
Very common break, your friend is right, solder that piece back and I bet your system will work properly
I think that maybe I'm dreaming..
Old 01-12-2016, 08:16 PM
Thanks for your response 964TargaC2. You happen to know what it is. Not critically important but just curious. I'll clean it up and solder it and give it a try then post the result. Thanks, Paul
Old 01-13-2016, 03:39 AM
know this is an old post.. but did the soldering work?! i’m have an issue with my locking system as well. it works perfectly then doesn’t periodically. like to know what your exact symptoms were, like to tell you mine.
Old 11-25-2022, 05:29 PM
Mine had the same break, I soldered and it worked!!! Thanks
Old 11-27-2022, 06:58 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Central locking.
Yes, cold solder joints can be very elusive.
Hope this helps.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-27-2022, 07:27 AM
