jwakil's Avatar
Cv boot question
I need to replace my torn cv boots. Why can’t I just buy the rubber part and reuse the same flange, bolts and locking straps (or use zip ties)? It seems our host and most other vendors only sell kits with the flanges and the rubbers already mounted, like in the picture. Is it very hard to mount the rubber on the flange ? I don’t see the need for replacing the bolts circlips and washers and gaskets.
Old 01-08-2023, 07:44 PM
jwakil's Avatar
Yes. I can find just the rubber parts for $25 set of four, but with the flange, bolts, gaskets comes to $300+.
Old 01-08-2023, 09:09 PM
jwakil's Avatar
Ok, so I guess it’s not easy to stretch and mount the boot on flange by hand? If I have to spend $170 on a tool then would defeat the purpose of just getting the rubber.
Old 01-08-2023, 09:18 PM
You've discovered the ever persistent problem in your question! Pay extra to have all new stuff that has been put together properly, or spend slightly less and use up hours of your time.
Up to you...
Old 01-09-2023, 11:14 AM
wrxnofx's Avatar
I used a set of bicycle tire irons to get my boots onto the flanges.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 01-09-2023, 01:48 PM
wrxnofx's Avatar
Get 4 of these: https://www.pelicanparts.com/More_Info/00004330644.htm?pn=000-043-306-44-M60&SVSVSI=590&DID=19433
Spend $50 total.
You don't need that tool above - plus it's from Dorman so it'll probably break on first usage
Bicycle tire irons work fine.
Old 01-09-2023, 01:53 PM
HarryD's Avatar
And to pinch the clamps, I used this: https://www.lowes.com/pd/Apollo/5013846251?cm_mmc=shp-_-c-_-prd-_-plb-_-ggl-_-LIA_PLB_142_Pipe-Fittings-_-5013846251-_-local-_-0-_-0&ds_rl=1286981&gclid=CjwKCAiAk--dBhABEiwAchIwkct713nm3nDxEG-7Vz9wOhYb7JWfWGPmAIVGXG7CtDdbxkTrQF32-BoCA2EQAvD_BwE&gclsrc=aw.ds
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-09-2023, 02:12 PM
jwakil's Avatar
Spend $50 total.
I have an 81’ so apparently for that car I have to buy the full kit which costs $350 for 4. That’s why I was asking if I can just get the rubber and use my existing flange. The rubber from another source will only run $25 total. $25 vs $350 justifies a little work for me. If a tire iron works and I don’t need that special tool then would be worth it.
Old 01-09-2023, 02:51 PM
Take the CV joint off the axle. No need to stretch a boot over the joint.
Rick
1978 911SC
Old 01-09-2023, 03:58 PM
HarryD's Avatar
Looks like you need this. Boot attached to plate already. https://www.pelicanparts.com/More_Info/92333203700.htm?pn=923-332-037-00-M60&SVSVSI=572&DID=7378
Harry
2020 MB E350 4Matic
Old 01-09-2023, 04:35 PM
Enginerd
TxGerman's Avatar
Not to send you down a different rabbit hole, but when I went through this last year I did a bunch of research (here and elsewhere) regarding the issues and risks of the driveshaft bolts coming loose (specific to the SC design, not 930 or 3.2). After evaluating many different engineering solutions, I decided to buy a full set of moon washers (I believe these are not stock to an SC....or at least were not on mine) which provides better load distribution and then decided to go with Stage8 bolts. That system gave me extremely high confidence that I would not ever have my drive shaft bolts come loose. Like I said....rabbit hole, but if you're already replacing or repairing your drive shafts, you may want to consider this upgrade.
1982 Guards Red 911SC, 1994 Riviera Blue RoW 993, 2017 GT Silver Turbo S, 2020 British Racing Green Macan GTS
Gone but not forgotten: 2012 Guards Red 991.1 C2S, 2017 Carrera White Macan GTS
IG: @pcar911fan
Old 01-09-2023, 04:51 PM
wrxnofx's Avatar
Exactly. But you still need to stretch the boot onto the flange.
Old 01-09-2023, 07:53 PM
Racer
winders's Avatar
Stage8 bolts don't stop the bolts from loosening enough to lose appropriate clamping pressure.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 01-09-2023, 08:44 PM
Not really; remove the CV joints, inspect and repack them, then affix the boot before you put the joint back on. Messy but a one banana job. A bit of manipulation is required but not the level of violence to the rubber that stretching the entire boot over the joint will induce. Anything worth doing is worth doing well.....the first time.
Old 01-10-2023, 03:10 AM
PCA Member since 1988
This. This is how I did it the last time. Messy, have lots of paper towel and wear gloves.
Old 01-10-2023, 09:05 PM
jwakil's Avatar
I ended up just getting the boots and reinstalling on existing flanges. It was not too hard to install the boots with a little bent spoon handle. But what a messy job. Holy cow! I went through a whole role of paper towels and then half the total time in trying to clean up. Getting the preinstalled flange/boot combo might have saved a little pain but not much since removing at least one joint is required regardless, so the mess is unavoidable unless you get the full axle assembly. I was surprised how much grease was still left in the joint as I'm sure they had been broken for some time, and it still looked fresh. I didn't bother doing a complete evacuate and regrease. It was too much mess and decided if the joints were to go bad, I would just replace the the whole axle assembly next time as the price is not that outrageous.
82 - Austin Mini 998
78 Mini 1275cc -totaled
83SC Euro w/77 3.0 Carerra Eng.--sold
Several other daily drivers not worth mentioning...
Old 01-24-2023, 11:26 AM
