how to remove door handle actuator/wire?
How do you remove the assembly with the actuator wire?
It looks like the assembly should slide off the barrell but a little pressure perpendicular away from the handle isn't doing it. I cleaned around best I could but it won't move and I don't want to apply to much force...
Any ideas?? Thanks.
_______________________
'85 Black ROW Coupe (trying to put back together)
'88 Blue 951 (sold)
'84 Blue couple (sold)
Old 01-29-2023, 04:34 PM
Small screwdriver under the side of the clip and it pops off.
206 637 4071
Old 01-29-2023, 05:42 PM
so John it pops up and off (vertical) not slide off the barrel? Thought about that but it looked a little brittle! Thanks for answer.
'88 Blue 951 (sold)
Old 01-29-2023, 06:12 PM
Uncertifiable!!!
Uwon's Avatar
Yes, it may be brittle and the side clip break like mine. A thin tie-wrap tightly strapped around the collar of the door handle solved it for me years ago. Still works.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 01-30-2023, 05:29 AM
Senior Member
finally,
I just did this on my car, as JW offered, small screwdriver, take your time, it will pop off. Make sure you take a look at all of the fittings and orientation of the cylinder in relation to the central lock sensor etc...
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 01-30-2023, 07:20 AM
Thank you Johan and Chris. When you pried off did you work from side the wire is NOT attached on?
As far as orientation the cylinder slipped out already but I saw a good YT vid on reassembly. Fingers crossed. Course I managed to scratch the handle finish (it peeled off way easier than I would have expected) so now I really need to remove this wire to refinish them again. Everything is a slippy slope.
'88 Blue 951 (sold)
Old 01-30-2023, 04:31 PM
Senior Member
I started opposite of the wire connection side. Once you get it pried up a bid, you will be able to grab the side with your fingers and pop it off. You will see the lip that snaps it into place once it is off. Again, make sure you take a picture of the orientation, and reinstall the lock screw insert. Removing and installing handles let to buying sidewinder handle ratchets
Chris
Old 01-30-2023, 05:47 PM
