I'm considering replacing the a/c compressor in my 84 with a rotary compressor. These are my questions:
1. Is the Sankyo (Sanden) SD-507 a rotary compressor? 2. Is it a 12 volt or 24 volt compressor? 3. If it's a 24 volt, why would someone try to use it on a Porsche? 4. Will it even fit on the 3.2 in my 84? 5. Can I rebuild it myself? Thanks for the help.
1984 Targa |
I have a Sanden in my 88 but I don't know the specific model. It came with a modified mounting bracket since the factory mount won't work with the Sanden.
Good Luck
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
The Sanden SD507 is a rotary compressor with a 12 volt clutch. I have fitted them to early (69-73) 911's with mechanical injection. I would have to believe you could fit one to a 3.2l motor. The only thing I believe that is rebuildable would be the shaft seal between the compressor and clutch body. Good luck!
JB |
I also have a Sanden rotary on my 83SC but am not sure of the model. It was changed by the PO. Definately 12 V. For fit, I think the important thing is the mounting bracket or adapter plate. The Pelican 911 Tech Articles have good info on Posche AC, as well as griffiths.com, procooler.com, and www.rpm.com.au/911/ . If your running R134, you should replace the old hoses with new barrier hose. It's a dirty job but not that hard or expensive if you get bulk hose from a local AC or hose shop and have your existing fittings crimped on the new hose. The consensus for cold AC in a 911 seems is to be either a 993 fender mounted condenser unit (with fan) and/or under body. IMHO, the 993 condenser is the way to go if you can finda used one at a decent price.
Jim Dowty 97 911 Coupe (Forest Green metalic, sunroof, leather) PCA RSR region Insurance chair and Board member Gruppe B #309 |
The Sanden is a "wobble-plate" design (not rotary) which is similar to the Nippondenso swash plate compressor you have on your car now (assuming your's is OEM).
Jerry M '78 SC |
Jmohn is correct the Sanden is not a rotary compressor, and neither is a Nippondenso, only the Seiko-Seiki is a true rotary compressor.
See Tech articles http://www.pelicanparts.com/911/911tech_articles.htm http://www.pelicanparts.com/techarticles/911_AC_upgrade/911_AC_upgrade2.htm |
Thanks for the information, guys. Much appreciated!
1984 Targa |
