Broken tabs on rear sway bar mount
Brought my car up because occasionally hear a faint clunk in the suspension and last time this happened it was a loose sway bar bolt. Sway bar bolts aren’t loose but I did find that the little tabs on the inside of my sway bar mount seem to have separated. The other side isn’t like this - and I have a mig welder - so I can probably make short work of this - just wanted to see if this was a common issue.
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250 Last edited by kyngfish; 03-10-2023 at 08:48 PM.. |
Better crop
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250 |
Not common on an 86, but more on the older chassis.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Elephant racing makes an upgraded mount. Might be worth welding in “while you are in there”
That said - I’ve been reading where those solid mounts put more strain on the chassis. Nice thing about the non solid mounts is that they have a little flex to them which - for a street car - seems like the right move. I would feel better about those solid mounts if they were engineered with a little more surface area to weld to the chassis to spread out the load.
I'm good with tools.
My 88 Coupe were broken upon receiving the car. Grab the welder and fixed the issue.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
Northern Motorhead
Wevo makes nice swaybar mounts , after repairing / welding mine twice on my 89 i went all out and welded in new units.
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
