Try not, Do or Do not
Henry Schmidt's Avatar
Twin Plug Is Here
SUPERTEC in conjunction with BurnBros now has the first twin plug distributors in the test phase.
Soon to be available.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-02-2005, 11:54 AM
DW SD's Avatar
LOOKS GREAT - congratulations! How much is the package?
1971 RSR - interpretation
Old 09-02-2005, 12:06 PM
Jeff Alton's Avatar
Cool Henry. Will this work on a 3.2 based motor running carbs? What else will I need and will you sell it as a complete kit including coils and wires etc??
Jeff
www.turn3autosport.com
Old 09-02-2005, 12:07 PM
Are there going to be versions to fit early cases?
Brooke
1969 911 ST 2.8SS EFI ITB (Irish Green), 1974 911 3.6 ITB (Black)
1952 MG TD with F20C
Old 09-02-2005, 12:08 PM
Zeke's Avatar
Last time Henry came on here about his MFI stuff I called and then faxed and he/they totally ignored my requests for pricing. Just thought you all would like to know.
Old 09-02-2005, 12:11 PM
3 restos WIP = psycho
kenikh's Avatar
Brooke,
I was talking to Aaron about developing one for the early case myself, using his button on my Bosh distributor. This would make an early dizzy compatible w/ the Jag cap, making parts availability much better than Bosch. I have been too busy to make traction, but it is very doable.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-02-2005, 12:12 PM
Walt Fricke's Avatar
Porsche Crest
I saw one which looked a whole lot like this (might be the same) at Carquip in Boulder, Colorado a couple of months ago. Call Marie there. 303 443 1343.
Walt Fricke
Old 09-02-2005, 12:26 PM
ejames19's Avatar
Sorry if this question sounds redundant. What is the benefit of having twin plug cap? Seems this has been discussed numerous times but I cannot find through search the benefits and what it all intails to convert on earlier model cars 'SC's for example. Cheers.
'No illusion is more crucial than the illusion that great success & money buy you immunity from the common ills of mankind, such as cars that won't start.'
'81 911SC Coupe
'03 MDX
'00 328i
Old 09-02-2005, 12:30 PM
drag racing the short bus
dd74's Avatar
Did you have the correct phone number, etc? Henry moved about a year ago.
When I call, he's always there, very polite and informative, etc. Henry's attitude definitely gives one trust in what he offers.
Anyway...Henry, way to go! That and the MFI is definitely material worth salavating over.
Old 09-02-2005, 12:33 PM
kenikh's Avatar
Twin plug cap means you can machine your heads for twin plugs. This results in smoother running, a more agressive advance curve and the ability to run higher compression pistons.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Zeke's Avatar
Yes, I spoke to someone who said I needed to speak with Henry hisself. Instead, I faxed a sheet asking for info ($) for my project. That was that. No reply. Did they get the fax? My machine says yes. No need to beat up on Henry, just my experience.
Old 09-02-2005, 12:38 PM
}{arlequin's Avatar
i barely comprehend an engine running on 6 plugs, so i'm kinda hesitant in jumping in on this for 20hp... nonetheless, pretty cool since it's gotta be considerably cheaper than the original units go for
nice work.
dave
1973,5
Old 09-02-2005, 12:51 PM
randywebb's Avatar
Twin plug cap means you can do twin plugs w/ a lighter dist. setup and still have the wider plug gaps for more power - not just improved 'feel'
also, it looks more like the early race cars than does the dual drive 964/993 dist.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 09-02-2005, 01:27 PM
I would rather be driving
jpnovak's Avatar
http://cgi.ebay.com/ebaymotors/PORSCHE-911-TWIN-PLUG-DISTRIBUTOR-911SC_W0QQcmdZViewItemQQcategoryZ107062QQitemZ4573 066485QQrdZ1QQsspagenameZWDVW
Old 09-02-2005, 01:30 PM
Licensed User
Shuie's Avatar
very nice
Old 09-02-2005, 01:40 PM
Kevin Stewart's Avatar
cool
Old 09-02-2005, 01:48 PM
Irrationally exuberant
ChrisBennet's Avatar
Twin plugs doesn't make much horsepower by itself but it lets you run higher compression with the same octane gas. That is the real advantage of twin plugs. As far as the advance goes, you actually run less advance with twin plugs. I *suppose* this results in less "negative work" as you don't need to start combustion as early.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-02-2005, 01:56 PM
kenikh's Avatar
-Chris
Heh heh; brain fart.
BTW: Twin plug Ebay search
Couldn't get the above link to work; More specifically:
Supertec Auction
I'd call this auction a "proof of concept" or "market pricing research"
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-02-2005, 02:08 PM
Plavan's Avatar
So $1400 dollars.... How much for the 964/993 derived one from Steve at Rennsport? I plan on making my 2.5L twin plugged. Just trying to compare costs.
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 09-02-2005, 02:39 PM
Jeff Alton's Avatar
Complete crank fire is cheaper than that...........
Not sure if your race rules will allow it though.
Jeff
Old 09-02-2005, 02:44 PM
