Can’t separate accelerator ball socket
Dropping engine on 88 3.2. I have removed the lock wire/pin but seems to be taking insane amount of force to separate the ball from the socket. Am I missing something or is it normal to take this much force? Don’t want to break something. TIA
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 03-26-2023, 11:48 AM
accelerator ball socket, which one ?
pull the pin, place a flat screwdriver behind the socket, next to the ball, pry or twist the screwdriver against the bellcrank , this should pop the socket off of the ball.
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 03-26-2023, 12:13 PM
proporsche's Avatar
looks like this..the pin is wrapped around the ball joint
1985 911 with original 502 191 miles...808 198 km
Old 03-26-2023, 12:36 PM
Yes that is it. I guess I just need to use a bit more force. Just seemed to be on there tighter than it should be. Thanks
Buck
'88 Coupe, '87 Cab,
Old 03-26-2023, 12:49 PM
proporsche's Avatar
in bad case disconnect it at the trans...and later at the engine.Slide it down and pry with a screwdriver of the linkage
ivan
Old 03-26-2023, 12:53 PM
As you may have notice there is a spring wire inside the cup. As you pry it should retract and let the cup separate from the ball. When I dropped my motor 2 years ago mine absolutely would not separate. Never sure why but my guess so much crud in the cup the spring would not move away from the ball. I pried mine so hard it bent the throttle linkage mounting plate on top of the engine case and then snapped the ball clean off. New cup end and mounting plate from Fleabay and all was repaired. Now I keep them lubed whenever Im in the area.
Old 03-26-2023, 04:39 PM
Spread the loop at the trans and pop it off the knob. Deal with the rest when the engine is out. When it won't come off the engine ball, 8mm wrench, loosen the nut and unthread it. Don't forget to reinstall before engine goes back in, 'cause there ain't no room then. And remember to tighten the loop again.
206 637 4071
Old 03-26-2023, 07:02 PM
Walt Fricke's Avatar
I think soaking the ball/cup with penetrating oil might help.
I, too, subscribe to the "crud behind the C shaped clip spring inside the cup" theory. With things apart I have been able to soak the cup, get the spring bit moving around, and clean out the stuff which prevents it from expanding in its slot to let the ball loose.
But I haven't tried the penetrating oil before getting the ball out. But should be worth a try?
Old 03-26-2023, 09:32 PM
In the past , l have used wd-40 overnight then used an open ended 8mm wrench to pry it apart.
Pete
Old 03-27-2023, 03:35 AM
superninety's Avatar
Lots of good advise already.
To visualize the open end wrench method, see the following video. He is using a tool for separating trim bits (search "trim removal tool"), but a standard open end wrench usually works well.
https://www.youtube.com/watch?v=fIWD24pTskU
Robert Callaway
PCA | Early S Registry | R Gruppe
1970 T Coupe, 1990 C2 Coupe, 2007 Cayman S
1962 S90 Coupe - Gone, but never forgotten...
1985 Targa - A distant memory...
Old 03-27-2023, 07:25 AM
wow that tool is brilliant. I have an old screwdriver I will modiy to make one of those. I also noticed that once I got them separated the "socket" side seems a little bunged up so maybe I damaged it when I removed it before. I may remove it completely and clean it up with my Dremel tool.
Buck
'88 Coupe, '87 Cab,
Old 03-27-2023, 09:27 AM
kevbo's Avatar
When you put it all back together make sure it snaps back in. I went through this process and hooked everything back up and though I was good. Then mine popped off while accelerating one day. After further analysis the joint needed to be replaced.
Kevin
1986 Carrera Targa
Old 03-27-2023, 06:12 PM
