Dumb question: Removing a crank sensor plug
At the engine side of my crank position sensor wire, I cannot remove the plug from the the vertical anodized bracket. Is there something that I need to do to get it out of that bracket. Thanks -Tom
you have to remove-slide out the security 3 point bracket.Sometimes it is also secure in place with mini phillips screw
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
