3.2 engine out service, what else should replace?
Hi folks, I am in the middle of my first engine out service on my 85 77,000 mile 3.2 coupe. I had oil leaks galore, and some vacuum leaks as well. I have a crunchy first gear syncro also, I am going to send the 915 out for a rebuild. Since pulling the motor and trans I have been busy cleaning 37 years of crud from every surface I can now reach, my engine insulation pad had disintegrated years ago so I scraped all of that crappy glue off everything. I am considering painting the engine bay and not reinstalling the chintzy insulation that I sourced from our host, I think my black on black car would look cleaner with a fresh coat of por 15 over the muddy off white underseal from porsche,its kind of disappointing the bay looks as standard, though being a reasonably low milage and mostly original it's never going to be a concours contender,so why not?. I intend to replace all of the oil return tubes and replace as many seals and gaskets as I can get to. I am going to do a valve adjustment as well. I'd appreciate it if you folk can offer any extra advice on the (while you are in there) list.?
Thanks. Andrew |
Fuel lines (your engine is out do the tunnels also if you can)
Any suspension items for the arms if you want as you can access the bolts with engine out Triangle o ring, gasket, switch. Rubber connecting both intakes Clean injectors right before install so they don't sit around vacuum lines spark plugs wires rotor cap coil Clean all grounds Clean all fuel rails Check FPR and Damper, replace if needed |
clutch
remove oil cooler and pressure test for leaks.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
While you have the oil cooler out look for the thin spot in the casting that may be leaking as per one of the service bulletins. Rear swing arm bushings previously mentioned.
Thank you for the feedback
I just cleaned my engine bay up, as long as the engine is pretty nobody really notices it. I hate the factory sound pad, so I used a quilted gold foil backed by butyl rubber that I custom made for it. I like it a lot:
IG@ADDvanced Youtube@ADDvanced www.gruvdesign.com |
oil cooler 3 seals when checking the oil cooler as mentioned. 2 are same size 1 is different size.
Cam lines ok? You are opening the can of worms like lots of us have when we go in there. I just went through the 40 year old "change ups" to sure things up. |
I think an engine bay sound pad is worth having; I would source a NOS pad if possible.
'71 914-6 #0372 '17 Macan GTS |
Why tho? All that pad is doing is stopping the resonance of that big flat panel. You can accomplish this with tons of different types of sound deadening pads, and it's not very visible. I don't understand paying a premium for something like that unless it's a factory style restoration.
The temp sensor, and two crank sensors.
Check and replace (as needed) the throttle linkage on the rear of the engine nearest the firewall. |
I already have a replacement pad from pelican, I read a thread where someone had installed it with magnets, I think I will paint the engine bay and use the magnets to attach the pad.
PCA Member since 1988
Don't forget to buy some CV joint gaskets too--the paper ones that go between the joint and the flange. Another good thing to do is install the metal covers/caps that go on the CV joints if it doesn't already have them. That makes it much less of a mess to remove and handle the axle
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
following... acquiring a drivetrain for my roller in the coming weeks and want to do what I can while I have it all out as well.
My cvs have the caps, there weren't any gaskets when I removed them.
Senior Member
Since you have the transmission off and are rebuilding it - obviously take a hard look at the clutch parts, rear main seal etc. When I had my engine out for the clutch job, I wish I had bitten the bullet and had all of the exhaust hardware replaced just to make any future work less painful.
Chris 1988 911 Carrera Targa (driving project started JAN 2022) 1970 911E - Long since gone 1972 911 Targa - gone 1987 911 Carrera - gone Retired FA-18C Driver |
I ordered a new sachs clutch and pressure plate, and throw out bearing. I also have a new rear main seal.
I heard that Dilavar studs need to be replaced ..... that can only done with the engine out. And the heads have to come off anyway, why not replace the valve guide seals.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
