3.2 engine out service, what else should replace?
Hi folks, I am in the middle of my first engine out service on my 85 77,000 mile 3.2 coupe. I had oil leaks galore, and some vacuum leaks as well. I have a crunchy first gear syncro also, I am going to send the 915 out for a rebuild. Since pulling the motor and trans I have been busy cleaning 37 years of crud from every surface I can now reach, my engine insulation pad had disintegrated years ago so I scraped all of that crappy glue off everything. I am considering painting the engine bay and not reinstalling the chintzy insulation that I sourced from our host, I think my black on black car would look cleaner with a fresh coat of por 15 over the muddy off white underseal from porsche,its kind of disappointing the bay looks as standard, though being a reasonably low milage and mostly original it's never going to be a concours contender,so why not?. I intend to replace all of the oil return tubes and replace as many seals and gaskets as I can get to. I am going to do a valve adjustment as well. I'd appreciate it if you folk can offer any extra advice on the (while you are in there) list.?
Thanks. Andrew
Old 04-17-2023, 11:46 AM
Fuel lines (your engine is out do the tunnels also if you can)
Any suspension items for the arms if you want as you can access the bolts with engine out
Triangle o ring, gasket, switch.
Rubber connecting both intakes
Clean injectors right before install so they don't sit around
vacuum lines
spark plugs
wires
rotor
cap
coil
Clean all grounds
Clean all fuel rails
Check FPR and Damper, replace if needed
Old 04-17-2023, 12:50 PM
theiceman's Avatar
clutch
remove oil cooler and pressure test for leaks.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 04-17-2023, 01:53 PM
While you have the oil cooler out look for the thin spot in the casting that may be leaking as per one of the service bulletins. Rear swing arm bushings previously mentioned.
Old 04-17-2023, 01:58 PM
Thank you for the feedback
Old 04-17-2023, 02:56 PM
ADDvanced's Avatar
I just cleaned my engine bay up, as long as the engine is pretty nobody really notices it. I hate the factory sound pad, so I used a quilted gold foil backed by butyl rubber that I custom made for it. I like it a lot:
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 04-17-2023, 03:07 PM
oil cooler 3 seals when checking the oil cooler as mentioned. 2 are same size 1 is different size.
Cam lines ok?
You are opening the can of worms like lots of us have when we go in there. I just went through the 40 year old "change ups" to sure things up.
Old 04-17-2023, 06:43 PM
Cairo94507's Avatar
I think an engine bay sound pad is worth having; I would source a NOS pad if possible.
'71 914-6 #0372
'17 Macan GTS
Old 04-18-2023, 07:44 AM
ADDvanced's Avatar
Why tho? All that pad is doing is stopping the resonance of that big flat panel. You can accomplish this with tons of different types of sound deadening pads, and it's not very visible. I don't understand paying a premium for something like that unless it's a factory style restoration.
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 04-18-2023, 09:48 AM
r_towle's Avatar
The temp sensor, and two crank sensors.
Check and replace (as needed) the throttle linkage on the rear of the engine nearest the firewall.
Old 04-18-2023, 08:48 PM
I already have a replacement pad from pelican, I read a thread where someone had installed it with magnets, I think I will paint the engine bay and use the magnets to attach the pad.
Old 04-21-2023, 01:10 PM
PCA Member since 1988
Don't forget to buy some CV joint gaskets too--the paper ones that go between the joint and the flange. Another good thing to do is install the metal covers/caps that go on the CV joints if it doesn't already have them. That makes it much less of a mess to remove and handle the axle
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-21-2023, 03:13 PM
ADDvanced's Avatar
I ordered some but they were for different axles, so I just torqued them down without them. So far no grease flying out. Idk if they're necessary.
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 04-22-2023, 07:59 AM
following... acquiring a drivetrain for my roller in the coming weeks and want to do what I can while I have it all out as well.
Old 04-22-2023, 08:55 AM
My cvs have the caps, there weren't any gaskets when I removed them.
Old 04-22-2023, 12:26 PM
Senior Member
Since you have the transmission off and are rebuilding it - obviously take a hard look at the clutch parts, rear main seal etc. When I had my engine out for the clutch job, I wish I had bitten the bullet and had all of the exhaust hardware replaced just to make any future work less painful.
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 04-22-2023, 03:00 PM
I ordered a new sachs clutch and pressure plate, and throw out bearing. I also have a new rear main seal.
Old 04-27-2023, 04:00 PM
I heard that Dilavar studs need to be replaced ..... that can only done with the engine out. And the heads have to come off anyway, why not replace the valve guide seals.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-27-2023, 04:25 PM
