Free minder
Is my mixture too lean?
Car is 1978SC.
I am assuming my mixture is too lean because I never readjusted it after switching from 8.5 to 9.3:1 compression, backdated exhaust and sport muffler. It runs fine but has a few symptoms below: - Cold starts are difficult, usually starts on 4 or 5 cylinders, then backfires and then runs on all cylinders just fine. - If colder, I usually have to lift the pressure plate to get it started. - If I set the idle air bypass screw to be 950rpm when hot, it oscillates when cold. - Backfires a little bit on deceleration - Spark plugs are light grey, very clean. So my plan is to richen the mixture a tiny bit. Other suggestions?
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) Last edited by Aurel; 05-15-2023 at 03:18 AM.. |
The first post of this thread might give you a clue as to whether you are too lean. Anyone local that might have a CO analyzer?
And I would check for any possible vacuum leaks first. CIS Idle Speed and Mixture Setting Without an Analyzer
Walt 82SC 3.0 81SC 3.6 Last edited by walt; 05-15-2023 at 04:55 AM.. |
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP Last edited by mikedsilva; 05-15-2023 at 04:43 PM.. |
I bought an AFR (air fuel ratio) meter after I messed around unsuccessfully with this. That gets me right on the money.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Targa_PB_78_SC
You are likely fine if you have an SC with lamda sensor, 78 not so good with OEM cat connection. Gets it right to 13.5 AFR at 1100 rpm with web cam 20/21.
BareRearedRookie |
Targa_PB_78_SC
Or here 911 CIS Primer - Testing: Although this is based on 14.7 AFR? Nothing beats the AFR meter. Mixtures
BareRearedRookie |
Targa_PB_78_SC
PS there is a nice video of a RUF slant nose Turbo here in the upper right corner. We can assume the mixture is correct,
I think ![]() https://www.rarelyl8.com/cis.html
BareRearedRookie |
PCA Member since 1988
+1 on AFR meter. It's so much more useful to know what your AFR is doing while actually driving it.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
back in the late 1970 in Czechoslovakia an oldtimer show me how to check emission , he used a larger march and put it behind the muffler pipe .If the flame went in it was lean to ok ,if it went away from the pipe -it was to rich.For tuning we actually use short way VKV radio..sounds
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Free minder
Thanks everyone. I will start with 1/8 turn to the right and take it from there.
AFR gauge is good advice, but this ain’t a turbo or high compression race motor, so I will play with the mixture screw first, and if I mess everything up then will reconsider AFR gauge.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
I found that adjustment to be quite sensitive. I would start with 15-20 degrees and take note of your starting position.
Walt 82SC 3.0 81SC 3.6 |
Free minder
I added about 1/8 turn richer. The car seems to run smoother, and does not backfire at all on decceleration. I am a the point as if I lift the air flow pressure plate it will stall, while before the idle would surge if I lifted the pressure plate. The true test will be a cold restart. If that is improved, then mission accomplished
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) Last edited by Aurel; 05-20-2023 at 06:32 AM.. |
Bland
You did what I would have suggested. If it’s oscillating, it’s too lean. I wouldn’t have gone more than 1/8 of a turn.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Still here
Decel valve adds air on decel which contributes to the lean backfire.
The best way to dial it in is with a gas analyzer. It’s amazing what the gas analyzer can pick up on. The analyzer is much more sensitive than an o2 sensor it’s easy to see if you have both and play around with the mixture. But hey if you don’t want to buy one or don’t want to take your car to a professional an o2 sensor is the way to go
it's not leaking....it's just marking it's territory |
82 911 SC - Ancora Imparo
1982 SC here. Lambda unplugged, Wideband O2 sensor and AFR installed. I am good with mixture / idle adjustment.
Just wondering what idle AFR people are running? Obviously I will be monitoring while driving to analyze AFR under WOT and other conditions to ensure the enrichment mechanisms within CIS are functioning correctly.
Ethan 1982 911 SC - Wine Red Metallic Coupe |
Ethan: As you may know, the Lambda CIS WUR does not have vacuum enrichment. It only enriches when you push the throttle past about halfway and trigger the switch on the throttle body that tells the OXS box to enrich to full load.
Please post your AFRs running open loop with the lambda unplugged. I'm curious what you end up with.
