Good to see it’s running, beautiful car!
Nothing should be making it through that filter, any residual problems is down stream, starting at the fuel pump. If you haven’t already flushed the fuel pump till it runs clear than that should be right up there with replacing the injectors.
Sea foam might help as well.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 08-30-2023, 05:25 PM
