Vertical steering wheel play after swapping steering wheel
Removed my OEM steering wheel, and installed a MOMO Prototipo Black Edition. And after installing, the steering wheel has vertical play slightly. Up and down only. The end of the bolt in the photo moves with the steering wheel when it moves. Do i need to tighten these? Only reason i could see it being lose after install is i used an impact and the vibration could have caused it to come loose. But i dont know. Need advice
Old 07-03-2023, 05:28 PM
Sometimes this antique ass forum pisses me off. Photo link wont post.
Old 07-03-2023, 05:29 PM
Senior Member
There is an easy bearing you can install, 10 minute fix.
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 07-03-2023, 06:52 PM
HarryD's Avatar
What year? Fix for 74+ different than earlier cars.
Please add you car to your signature line. Help us help you.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 07-03-2023, 08:15 PM
Its an 87 carrera
Old 07-04-2023, 07:41 AM
I ordered the Rennline nylon steering column support bushing through pelican. Thats what i needed right?
Old 07-04-2023, 07:42 AM
Senior Member
That should work for you.
Chris
Old 07-04-2023, 09:58 AM
The part i put in my SC was a upgraded part for a 928 metal not plastic. P/N- 92834773902 available from our host.
Old 07-05-2023, 07:40 AM
HarryD's Avatar
There was a discussion here a few years back about the 928 sleeve. I believe it was John Walker who brought up the issue. The Rennline unit solves that problem.
Harry
2020 MB E350 4Matic
Old 07-05-2023, 09:27 AM
What was the issue ?
Old 07-05-2023, 12:46 PM
I have said bushing and a plan to install - I'd too like to understand the called out issue before I proceed.
Old 07-05-2023, 12:50 PM
Will update after it comes in and i install
Old 07-05-2023, 01:04 PM
HarryD's Avatar
Search is your friend.
https://forums.pelicanparts.com/porsche-911-technical-forum/372487-problems-arising-metal-steering-bushing.html
Originally Posted by john walker's workshop View Post
i posted a while ago about steering shaft wear from metal bushings. grease those things on the inside with something like opti-moly or the grease that comes with ignition points. i've seen severe wear on 2 shafts to date.
The 928 sleeve has a lip you can pry under to work it outward. Most just slipped in with a couple light taps. To replace the bearing, you have to remove the whole upper housing. not an easy job, so best to avoid that. I've seen a few steering shafts worn from rotating for years in that steel bushing, so check that.
Harry
2020 MB E350 4Matic
Old 07-05-2023, 01:18 PM
