Are the fronts fiberglass?
206 637 4071
Old 08-03-2023, 01:18 PM
proporsche's Avatar
nice look at your 911`s rear looks great...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 08-03-2023, 01:29 PM
tobluforu's Avatar
Did they not cover anything when they painted it? I mean it looks like they painted the muffler, shocks etc..? And, they should have mocked up the rear muffler with the rear bumper and notched it for the tips before spraying.
Old 08-04-2023, 04:19 AM
Diss Member
Quicksilver's Avatar
I'd get under there and start measuring the position of the passenger side ball joint compared to some of the control points and then take those numbers and compare it to the same measurements on the driver's side. That will tell you how far out you are.
I guess the real interesting measurement would be from the back of the A-arm where it is welded to the tube, over to the control point marked as "C".
If there is a difference between the 2 sides it should be pretty apparent where the difference is.
For reference...
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 08-04-2023, 05:19 AM
Grappler
Rodsrsr's Avatar
Did OP ever find out what the issue was?
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 08-18-2023, 05:35 PM
They were welded wrong and just re did them. My twist of an RSR is getting close to the finish line now. I am the tinkering phases of making my own carbon parts for interior/exterior.
Dropped a fresh3.6/PMO’s/ with electromotive HPV-1 and paired it up with a built 915.
Who makes a “cleaned up” version of the engine wire harness? All i really need is lights, tach and alternator correct?
Old 01-07-2025, 12:48 AM
Something doesn't seem right on that fender.. show pics of the other side and front end.
Looks like a 914 wide body kit imo.
Ahh... it's solved then. Nice car.
Old 01-07-2025, 08:52 AM
7.0:1 > 11.3:1 > 7.0:1
Looks good. Pretty nice car you built.
Old 01-07-2025, 09:29 AM
