Hey! Nice Rack! "Celette"
rich's Avatar
Looking for a source for CIS Injector Tubing
I have a 73 2.7S and need to refurbish the CIS. Anyone know where I can purchase bulk plastic tubing for the CIS fuel lines?
Early Alien Sightings
914-M28/11 5.0 Hybrid (The Alien Sharkster)
I think I smell your blood in the water
WCC 04 done by the kids
Who says Aliens only abduct people.
Old 08-18-2023, 03:46 AM
BelMetric carries several sizes and types of fuel hoses, including polyamid, which may be what you’re looking for. Give them a look online, I’ve had good success with them in times past.
Old 08-18-2023, 04:37 AM
Schulisco's Avatar
Forum search is always a good tool
https://forums.pelicanparts.com/search.php?searchid=25319219
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 08-18-2023, 04:57 AM
Be careful sizing/sourcing the fuel tubing. There are multiple sizes in the CIS system.
The correct polyamide tubing for CIS injector lines (from the fuel distributor to the injectors) is Cohline part number 3012.0206 which is 2mm ID x 6mm OD.
There are others selling tubing with reduced wall thickness that will lead to injector pulsation over time.
I have not found the Cohline injector tubing available for sale in the USA the last time I purchased some (~18 months ago). I had to order from Europe:
https://cohpro.com/product/polyamide-tube-2mm-id-6mm-od/
Old 08-18-2023, 06:43 AM
Try the online company belmetric.com
They specialize in selling metric fuel lines vacuum lines and all kinds of metric fasteners.
They carry different sizes of the polyamid plastic line that is used for the fuel injection lines. Hope this helps.
It looks like the information posted just above mine is better to go by from fanaudical It sounds like he has the better source in Europe to order from
Old 08-18-2023, 06:44 AM
rich's Avatar
Thanks! Great Response!
BTW I did a search but came up with Zip. Possibly my search words but anyway I knew someone would have a source.
Old 08-18-2023, 07:27 AM
Schulisco's Avatar
https://urlis.net/1hybc80a
https://urlis.net/poue0gu1
Unfortunately out of stock currently.
When you search with the Porsche Part number (see from the links above) you get much easier some results:
911.110.093.11
911.110.093.12
https://urlis.net/ysg6tdar
https://urlis.net/u22j704u
Thomas
Old 08-18-2023, 08:26 AM
rich's Avatar
When you search with the Porsche Part number (see from the links above) you get much aeasier some results:
911.110.093.11
911.110.093.12
Thomas
Thank you sir. Just want the bulk tubing without fittings.
Old 08-18-2023, 09:37 AM
theiceman's Avatar
what about the exterior sheath that goes around it ? mine all broke away .. i'm sure it is not required but just does add that finishing touch.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 08-18-2023, 10:16 AM
Schulisco's Avatar
I wouldn't take the risk and replace it. When the exterior sheath broke, then the rest won't be in better shape... The costs to replace it are literally nothing compared to a burned down 911...
Thomas
Old 08-18-2023, 11:02 AM
You could also try Belmetric dot com something. They have fittings and tubing. The exterior rubber is for protection against chafing I think, it will crack. The Polymide tubing is very stable, however, in comparison to the rubber.
1978 Targa - 1980 3.0; Carrera intake; Megasquirt 2; EDIS ignition; 22/28 mm torsion bars and late Carrera sway bars; Carrera front brakes. Targa top rebuild in 2017. Suspension rebuild in 2019. Needs new paint and interior carpets.
Old 08-18-2023, 11:35 AM
rich's Avatar
Belmetric responded. No tubing. Checking the Cohpro. Waiting for a response.
Old 08-18-2023, 11:40 AM
Mark Salvetti's Avatar
Try Unobtanium Supply. Ferrari's had CIS. They list kits in their catalog: http://www.unobtainiumsupply.com/UnobtainiumSupply_Product_List.PDF
They also have a tool for attaching the fittings, which is not a trivial exercise. See the last page.
These guys too: CIS Fuel Injection Fittings, Line, Banjo Fittings Midwest Shop Supplies
Lots of good threads here on replacement, here is one: How to Make Fuel Injection Lines
Or have BoxsterGT make you a new set.
Mark
1979 911SC Targa
Old 08-18-2023, 12:54 PM
E Sully's Avatar
I ordered from Verell Unobtainium at Ferrari Chat back in 2011 and the tubing was correct for my '73.5
Heres the old thread. The J2 Precision links seem to be expired
CIS Fuel Lines
The line Verell sold was Cohline 3011 3106 HIPHL-23. 6mm od vinyl Polyamide (vinyl) tubing. You don't want anything with a thinner wall as it could flex enough to cause injectors to pulse.
This is the closest I found from Cohline https://cohpro.com/product/polyamide-tube-3-15mm-id-6mm-od-black/
Ed
1973.5 T
Old 08-18-2023, 02:27 PM
47silver's Avatar
Len (boxstergt). Is the tubing guru.
Send your fittings to him, get new ones back
Len Cummings
len.cummings@verizon.net
It is doable on your own. Search here for people that did them
Old 08-20-2023, 07:02 AM
BoxsterGT's Avatar
Porsche Crest
This......
len.cummings @ verizon.net without the spaces.
Old 08-27-2023, 02:12 PM
Travis Neff's Avatar
Parts Klassik has the bulk cohline polymide
p-1863-polyamide-line-3mm-thick-wall.aspx
72 914-6 GT Conversion 2.7
82 911 SC Coupe
78 SC Targa Hotrod
Old 08-29-2023, 04:23 PM
rich's Avatar
Hey Travis!! Miss you guys! I ordered some from Cohpro. It was super cheap I ordered 6 meters was less than $ 40.00 shipped.
Old 08-29-2023, 07:47 PM
rich's Avatar
The Alien had to Christen the new driveway
Old 08-29-2023, 08:09 PM
HarryD's Avatar
FWIW, the early 911 CIS did NOT have the sheath on the tubing.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 08-29-2023, 09:20 PM
