Chain fence eating turbo
Anyone have a schematic for the vacuum lines on a Carrera 3.2?
My has car has been so modified for the turbo system, I don't know sometimes if things are in the right place.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 02-16-2012, 01:18 PM
Flat Six
Flat Six's Avatar
Tippy, is this what you're looking for?
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 02-16-2012, 01:51 PM
Yes! Thanks!
Old 02-16-2012, 01:58 PM
porwolf's Avatar
Hi FatSix, do you also happen to have a vacuum shematic for a 79 SC?
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 02-16-2012, 02:32 PM
Flat Six
Flat Six's Avatar
Sorry; I just archived this one since I have an 85 3.2 . . . can anyone else help a brother out?
Dale
Old 02-16-2012, 02:40 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Vaccum Lines.
Here's a few more for the 3.2.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 02-16-2012, 02:42 PM
Flat Six
Flat Six's Avatar
Porwolf, check these three links:
key for this 911SC vacuum hose diagram?
need '81 SC vacuum diagram
http://members.rennlist.com/jimwms/CIS/CIShome.html
Dale
Dale
Old 02-16-2012, 02:43 PM
What is that switch behind the throttle body with 2 ports?
I forgot.
Old 02-16-2012, 02:50 PM
porwolf's Avatar
Thanks for the links, FlatSix!
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 02-16-2012, 02:51 PM
steely's Avatar
That is the temperature switch in Flat Six's decal.
The micro switch behind that in the photo that 86 911 Targa uploaded is the idle micro switch.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 02-16-2012, 02:53 PM
I'm asking about the switch/sensor that has the two vacuum lines in that picture.
It's left of the idle microswitch in that pic.
Old 02-16-2012, 03:05 PM
Gotta stop looking at pics on my iPhone, no zoom capability on Pelican. I see it's a temperature switch.
What exactly does it do?
Old 02-16-2012, 03:07 PM
Vaccum Switch.
I forgot.
It's a temperature/vacuum switch for the vacuum lines going to the fuel pressure dampers. (24).
(NLA).
1986 911 Targa.
Only in L.A.:
Old 02-16-2012, 03:12 PM
Ah, I see what it does according to "Flat 6's" pic.
It is "T"d to the intake vacuum port on one side and then an outlet port to the oil tank.
It must cut vacuum to the oil tank until the engine is warm I assume?
Old 02-16-2012, 03:25 PM
bringing this back to life - trying to confirm what the temperature vacuum switch controls when hot. It appears to have one hose the goes from the switch back to the throttle body/intake - the other appears to go from the switch to the vacuum switch over by the oil tank. Is this correct? Earlier post claims it controls the fuel regulator and fuel damper - but my 85 3.2 is not set up that way - want to make sure all my lines are going to the correct place as I am hunting down vacuum leaks contributing to cold start issues.
Yours,
Dave
1985 Carrera 911 Cabriolet - Grand Prix White / Black interior and top.
Old 10-22-2019, 05:48 AM
carreradpt's Avatar
Anyone happen to have a good couple of pics of the backside of a 3.2 to capture the routing of the vacuum lines? Those pics are helpful Gerry, just looking for a few more for detail.
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 06-24-2020, 01:54 PM
Hi Guys, new here
Can someone post the other end of this tube??
I can figure out where it goes!
Old 10-08-2021, 12:26 PM
That's fond- just deglaze
Hi Nader2- That appears to be Part #30, which ends at the Recirculating Air Valve (#93020722702) located next to the oil fill cap.
Hope this helps!
Missed Approach
Petra- 1986 Coupe
Old 10-08-2021, 01:02 PM
I've been search but can't seem to find what the part # is for 24A is in the pic. Can it be purchased separately? The rubber section on mine has a crack and I can probably repair it pretty easily, but wondered if it can be purchased.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 08-21-2023, 04:50 PM
Hi 88911Coupe-That's 93011032805, which is available from our host...
https://www.pelicanparts.com/More_Info/93011032805.htm?pn=930-110-328-05-M100
Hope this helps!
Missed Approach
Petra- 1986 Coupe
Old 08-21-2023, 05:46 PM
