scottb's Avatar
Rotary A/C Compressor
What advantages does a rotary a/c compressor have over the stock Nippondenso in my 84?
Anyone have a rotary they'd be interested in selling?
1984 Targa
Old 06-12-2003, 11:16 AM
The advantage is less strain on the motor. You can bearly feel the rotary compressor when it cuts on.
Old 06-12-2003, 11:29 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Well, as you know, i don't have one, but i believe the advantages mechanically are that the rotarie's are smaller and lighter. Because of mechanical design, rotaries go through a "pump" cylce three times per revolution. Therefore it can be smaller than a piston pump but yet compress the same volume since it does it more times per rev.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 06-12-2003, 11:35 AM
sithot's Avatar
Correct on all counts. Rotarties can be felt in our engines; the pulsing of the pistons. When you turn on the a/c you will feel the compressor. Good time to change out and go with the new coolant (R134) as well. Freon is not going to get any easier to find and it is expensive.
R Gruppe #111
Early S Registry #235
res ipsa loquitur
Old 06-12-2003, 11:42 AM
scottb's Avatar
Aside from it being smoother, does the rotary provide any additional cooling?
1984 Targa
Old 06-12-2003, 11:52 AM
I changed to rotary and at the same time changed to R134. It does not cool as well as it did with the original compressor, but close. The good thing is I can add R134 for about $5.00 a can and I can do it myself.
Old 06-12-2003, 11:55 AM
1fastredsc's Avatar
I'm told that freeze 12 is supposed to be really good stuff. But i don't know first hand since i hate ac, roll down the windows, roll on the throttle!
2007 Mazda 3 hatch
Old 06-12-2003, 12:01 PM
scottb's Avatar
Can anyone give me the correct brand and part number for a rotary compressor that will fit my 84 3.2?
Thanks.
1984 Targa
Old 06-12-2003, 02:20 PM
