I'm good with tools.
AG81's Avatar
Frunk
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 08-10-2024, 09:26 AM
Originally Posted by AG81 View Post
Test fitting the carbon fiber mini duck made by fellow Pelican Jonny042.
This part is some of the finest fitting carbon fiber I have ever dealt with.
It will be painted !!!! I love carbon fiber but the look of it on a long hood doesn't work for me.
Thank you Jon.
That looks sharp.....
Old 08-11-2024, 09:18 PM
AG81's Avatar
Update:
So my 2.7 case is back from the machine shop. Pinned, line bored, bypass, and a few other original issues. I have purchased a new set of pistons and cylinders. I went with a RS style flat top to gain a bit of room (valves) so I'll have a better cam selection available. New PMO carbs. I had the head work done locally and sent the guy my intake to see if he could match them up to my heads. Things are moving along...... slowly.
I feel I've made smart, frugal decisions with this motor but the cost is still going to be in the $35K range.
Costs add up fast. New Carbs, Cams, Pistons, Cylinders, Intake, Heads, Case Work, Labor, Coatings.
02 996 4S
Old 09-10-2024, 05:44 AM
(man/dude)
Jonny042's Avatar
Update:
Tell me about it! Case machining alone just about killed me...
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 09-10-2024, 11:04 AM
AG81's Avatar
Wheels back from Fuch Restoration:
Decided on Pirelli 195/65/15 tires.
Has anyone utilized a spacer with 15x6 Fuchs ? Maybe push the rear wheel out a bit?
If anyone is interested in a brand new set of 16x7 Group 4 Wheels, Style LMZ
ET 23.3 . Please PM me. The tires have zero miles.
Conti Extreme Contact DW06 Plus. 205/55/16.
I'll make you a fantastic deal on these. Cheap.
02 996 4S
Old 09-28-2024, 02:04 PM
AG81's Avatar
Finally my heads are moving forward.
Cams are here.
02 996 4S
Old 10-12-2024, 02:07 PM
tobluforu's Avatar
35k, yikes! What cams did you go with?
Old 10-14-2024, 09:37 AM
AG81's Avatar
Yikes is right. S cams.
Case work
Shipping
New intake
New PMO's
Filters
Crank polishing
Head work
Oil pump serviced
CSF oil cooler.
New Rods
New Pistons & Jugs
New bearings
Bolts
New valve covers
Coatings
New Fan
Alternator
I am sure I am forgetting something.
I bet this will be over 35K closer to 40K
02 996 4S
Old 10-14-2024, 09:53 AM
PCA Member since 1988
Re the 15x6 Fuchs and spacers (I'm surprised Bill V didn't post a bunch of tables of wheel and tire fitments already ). The 15x6 have an offset of 36mm, so they are very close to the same wheel outside edge as the 16x7's with ET23.3. IME, it will depend more on the specific tires you want to run than the width and offset of the wheels. I tried spacers on my 1973T in the past with 15" wheels, but didn't think they were worth the trouble. You probably won't be able to use more than a 1/4" spacer on a narrow body car. But, mount the wheels and tires and jack up the right front corner good and high, to compress the left rear wheel. Then stick your fingers or popsicle sticks up there to see how much clearance you have. FYI, on most of the early cars I have seen, the left rear fender is a little bit closer than the right rear fender, so that's where I have rubbed tires first. That's why I suggest compressing the left rear wheel. .
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-14-2024, 05:11 PM
It is looking good
Originally Posted by nickelplated5s View Post
What's that white P car in the corner?
Old 10-14-2024, 07:10 PM
AG81's Avatar
PeteKz..... Thank you. Yeah I got some figuring out to do but need to get my motor finished and back in the car so I can establish a ride height.
02 996 4S
Old 10-15-2024, 06:14 AM
AG81's Avatar
Originally Posted by HRogue View Post
It is looking good
Thank you HRogue.
02 996 4S
Old 10-15-2024, 06:15 AM
tobluforu's Avatar
S cams are pretty much, all top end, as you most likely know. Have you thought about solex cams, it's what I run, best of all worlds. Great mid-range, lose a tad bit of top end compared to S. More Street friendly.
Old 10-15-2024, 07:25 AM
AG81's Avatar
tobluforu....
I seemed to have talked this topic to death with a lot of folks I respect, Ed Mayo and Chris Almod to name two. Considering my type of spirted driving, the head work I am having done, the new carbs, headers ect., it was decided to go in the S cam direction with some tweeking done to those cams. I don't speak "CAM" but Mr. Mayo does and he had these made for this engine. I relied heavily on his 60 years of experience. I appreciate your input greatly.
02 996 4S
Old 10-15-2024, 08:34 AM
skinnerd's Avatar
As you increase displacement, S cams become less and less peaky.
On a 2.7RS spec motor for instance, they work fine even at lower RPM's.
On a 3 or 3.2 liter, S cams are golden.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 10-16-2024, 02:13 PM
AG81's Avatar
Fantastic insite skinnerd. This motor was designed to replicate a 2.7RS.
02 996 4S
Old 10-16-2024, 06:55 PM
Rosco_NZ
Send a message via Skype™ to Rosco_NZ
Mod-S cams even better with wider LSA
Old 10-20-2024, 09:47 AM
tobluforu....
Ed is like The Wolf in Pulp Fiction…”that’s all you had to say…”
Ass-engine Nazi slot car -- PJ O'Rourke
Old 10-20-2024, 06:55 PM
Beautiful work...
Old 10-20-2024, 08:45 PM
AG81's Avatar
Thank you fanaudical.
02 996 4S
Old 10-21-2024, 05:43 AM
