3.2 Head Temperature Sensor curiosity
My '85 Coupe wouldn't start in cold weather (under 40F). I tested for spark - good. I could smell gas. I assumed the Idle Control Valve controlled air during start-up so I checked it - good. Then checked the Head Temperature Sensor (CHT) using the paperclip bypass method - - bingo, started right up. The CHT had already been changed with a 2-wire, but it looks like that failed as well.
Question - could someone explain what the CHT does to affect fuel/air mixture for cold starts. Knowing how to fix stuff is a lot more gratifying when I understand what it is I did. Thank you in advance!
Dave
Old 12-04-2023, 01:40 PM
Chain fence eating turbo
Originally Posted by Another911 View Post
My '85 Coupe wouldn't start in cold weather. I tested for spark - good. I could smell gas. I assumed the Idle Control Valve controlled air during start-up so I checked it - good. Then checked the Head Temperature Sensor using the paperclip bypass method - - bingo, started right up.
Question - could someone explain what the Head Temperature Sensor does to affect fuel/air mixture for cold starts. Knowing how to fix stuff is a lot more gratifying when I understand what it is I did. Thank you in advance!
The CHT tells the computer when it is cold that there needs to be additional fuel injected during warmup. I believe the cutoff is 155F and the engine is considered warm.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 12-04-2023, 01:46 PM
Most likely you have a bad temp sensor (open). If it's a signal wire one, it needs to be upgraded to a two wire.
Dave
Old 12-04-2023, 01:53 PM
917_Langheck's Avatar
Always refer to the source... :-)
Old 12-04-2023, 09:14 PM
The OP later added the two wire sensor info after two posts.
Dave
Old 12-05-2023, 05:05 AM
I probably misunderstand it, but since the CHT is a NTC sensor, substituting a short (paperclip or whatever) would trick the ECM into thinking the engine is warm, right?
So I wonder how that trick helped the OP with cold start under 40F ambient?
Gilles
RoW 88 Carrera coupé
Old 12-05-2023, 07:40 AM
Yes, keep one in your glovebox.
The engine was most likely flooded even at 40F, so shorting the sensor allowed the engine to start sooner (leaned mixture).
Dave
Old 12-05-2023, 10:28 AM
Got it. Thanks!
Gilles
Old 12-05-2023, 11:31 AM
Well, that's just not cricket!
Old 12-05-2023, 11:13 PM
Mr. Merk's Avatar
Mine failed a couple years ago when I was 9 hours from home on the way back from Luft Indy. Luckily it was already warm, and I was able to ground the connector to the intake manifold and drive home without issue. (we ripped some horn wiring out of my buddy's 930 to make a jumper)
It did NOT want to cold start though. It took forever to get it started.
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS
SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo
Workshop Coordinator at Ehrlich Motorwerks
instagram.com/patrickossenkop
ehrlichmotorwerks.com
Old 12-06-2023, 08:33 AM
You forgot your paper clip in the glovebox, right? For cold starting, you can remove the paperclip for a one second crank, and re-install.
Dave
Old 12-06-2023, 10:17 AM
Mr. Merk's Avatar
Ha, I wish I knew that trick at the time.
Jumper both terminals together for cold start, and ground to intake to run/hot start.
Old 12-07-2023, 07:51 AM
Hot start & running - just jumper two pins on female connector
Cold start - momentarily (few seconds) remove jumper while cranking
Dave
Old 12-07-2023, 08:43 AM
theiceman's Avatar
no .. the reason it worked for him is because his particular issue was a flooded engine. The HTS was not the route cause of his issue, but shorting the sensor with the paperclip leaned it out helping it start in this particular situation.
The issue still remains of why it flooded and did not start in the first place.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 12-07-2023, 10:25 AM
Mr. Merk's Avatar
When my sensor failed, it flooded and raw gas was emitting from the tail pipe.
Old 12-07-2023, 03:39 PM
It appears, per the OP's statement, that the replaced 2 wire sensor failed in the open state causing a flooded engine.
Dave
Old 12-07-2023, 07:23 PM
