Somatic Negative Optimist
Porsche does not recommend additives but there is evidence that Graphite-based products like "Moly Lube" reduce friction. Has anyone used additives? JW or Wayne, what is your experience or opinion? Thanks.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ". ![]() |
Information Junky
DON'T DO IT! . . .or even think about it.
Graphite is a fine DRY lubricant, but has no business being mixed in a motor oil.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee. ![]() |
Montana 911
ditto
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
Early_S_Man recommended the Swepco 212 w/moly to me and it's been working great in my tranny for months. It's also multi-viscosity so it has a higher heat range.
Matt '82 911SC Targa! |
Moly and graphite are different additives.
Unregistered
Graphite and teflon oil additives = snake oil. Molybdenum disulfide is a different story. I would not put it in my engine but in a trasnsmission where the gears need an extreme pressure grease I can see some benefit.
Information Junky
Apparently there is a concoction called "G-M lube" or "Graphite - Moly Lube" . . ..a mix of graphite with molybdenum disulfide.
It's said to be "thee thing" in lubricants, for Pinewood cars. So, obviously, it must make 911's faster too. ![]()
Do a search on Dow Corning's Molykote M Gear additive, fantastic stuff, and I use it in all my transmissions.
http://www.dowcorning.com/applications/Product_Finder/PF_details.asp?l1=003&prod=01005855&type=PROD&pg=00001044 Moly vs. not...Gear oil question Last edited by Steve W; 06-22-2003 at 11:45 AM.. |
Thanks for the input. It seems that "Moly" in transmissions is o.k. but people stay away from any additives in the engine. Sounds good to me.
![]() Quote:
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Moly is of course absolutely essential for proper camshaft break-in. There's no need for it in the engine after this initial period.
Thread Tools | |
Rate This Thread | |
